Oil temp or oil pressure - gauges? >
Old 08-03-2005 | 08:45 AM
dockrocker's Avatar
Default Oil temp or oil pressure - gauges?
Looking at possibly redoing my dash this winter (if we keep the boat) - I have a bit of room to move things around, but I'm wondering what you feel is the "minimum" amount and type of gauges, and what you would add if possible.
Boat is a 29' twin, stock Merc 330 hps. Will not be upgrading power, this boat will stay with standard, start every time Merc black motors.
Thanks!
dockrocker is offline
Old 08-03-2005 | 08:51 AM
Wobble's Avatar
SORE MEMBER
Default Re: Oil temp or oil pressure - gauges?
Min. amount would be tach, oil pressure, water temp. desirable options would be oil temp, fuel pressure, water pressure. IMO
Wobble is offline
Old 08-03-2005 | 03:54 PM
Airpacker's Avatar
Oil temp is a critical one if ya ask me. It can show you things are going wrong way before any thing else will.
Airpacker is offline
Old 08-03-2005 | 06:14 PM
formula31's Avatar
vacuum
formula31 is offline
Old 08-03-2005 | 06:32 PM
Pwrbt33's Avatar
I agree, Tach, water temp, oil temp, oil pressure, water pressure and volt gauges. Oh yeah, and those 2 cute little lights that glow and say "WARNING....WARNING!!!!!"
Pwrbt33 is offline
Old 08-03-2005 | 06:39 PM
Hydrocruiser's Avatar
Arrow Re: Oil temp or oil pressure - gauges?
... Dock...don't forget the "water pattern step spray indicator"...
..bubble light too.
Hydrocruiser is offline
Old 08-03-2005 | 09:45 PM
vette131's Avatar
Originally Posted by formula31
vacuum
i have a couple gafrig vacuum gauges im taking out of my cig & replacing them with water pressure if anyone wants them.
they were installed by the previous owner. i think it's more important to know when an impeller is about to fail.
vette131 is offline
Old 08-03-2005 | 10:33 PM
dockrocker's Avatar
Hydro, straight V hull, no step on this boat!
Fred, I was already out on your site pricing the gauges - if I go ahead with this, I'll be calling you for some advice. I hear you've replaced a gauge or two in the past...
Old 08-04-2005 | 09:09 PM
formula31's Avatar
they were installed by the previous owner. i couldn't find a use for them in a boat.
Obviously clueless. They will tell you much about intake and valve condition. Excellent prewarning to something bad going on in the top end. The area most big block have problems.
Old 08-04-2005 | 10:47 PM
vette131's Avatar
wasn't trying to start anything. big cams equal low vacuum at idle. get on plane & they hardly have any vacuum due to engine load. as far as being clueless i doubt it. i've been a ford tech specializing in drivability & electonics for 20+ years.
like i said wasn't trying to start anything, i just think if you have limited room for gauges, vacuum would not be on my list.
vette131 is offline
