Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Bottom of boat is flaking?  Can I use it one more time before repair? >
Old 08-03-2005 | 01:48 PM
Harper220's Avatar
Default Bottom of boat is flaking? Can I use it one more time before repair?
I have a 2001 28 Daytona and I recently noticed this 5 to 6 inch diameter spot on the bottom of boat about 10-12 ft up from transom and 1 ft in. It's on the surface and it's flaking. I'm positive that I didn't hit anything and I've been told it might be delaminating. It can be fixed for about $200-$300, but not till next week. My question is: Will I be OK to run the boat one more time until repaired? Kenny at Eliminator said it shouldn't be a problem and the guy that will repair it also said the same thing. If this is in fact delamination, I was told it needs to flake out anyway to get the bad part off.
I don't know much about fiberglass and I'm concerned about taking it out? Will I be ok or not? Thanks
Attached Thumbnails Bottom of boat is flaking?  Can I use it one more time before repair?-dcp_0549-small-.jpg   Bottom of boat is flaking?  Can I use it one more time before repair?-dcp_0551-small-.jpg
Harper220 is offline
Old 08-03-2005 | 02:53 PM
Sean H's Avatar
A to Z
Default Re: Bottom of boat is flaking? Can I use it one more time before repair?
i wouldn't run a boat that is delaminating... you will be forcing water (at a pretty good pressure if you run your boat hard) into the edge that is coming apart... the "good" fiberglass beyond the flake might not be able to withstand this... after that, your coring is next on the damage list...
Sean H is offline
Old 08-03-2005 | 05:44 PM
Harper220's Avatar
From the looks of the pics, does this look like delamination to you? Just curious?
I think I'll just leave her parked till it's fixed. Dam it, I had a boat load lined up for Sat. too...
Old 08-03-2005 | 06:24 PM
Sean H's Avatar
A to Z
http://www.nautica.it/info/maint/delamine.htm
some good reading there.....
Sean H is offline
Old 08-06-2005 | 02:04 PM
SUPERSTITIOUS's Avatar
http://www.nautica.it/info/maint/delamine.htm:
SUPERSTITIOUS is offline
Old 08-07-2005 | 01:15 PM
ratman's Avatar
that looks scary dude, i wouldn't want to chance it unless i owned a marine salvage company i mean whats the worst that can happen?
ratman is offline
bcarpman
1
07-18-2008 05:08 PM
Bottoms Up
01-21-2007 05:58 AM
topher117
12-15-2006 07:58 PM
RMM
0
03-16-2004 01:07 PM
WETTE VETTE
06-20-2002 01:11 PM
