Awesome 26 with twins - Which way do I rotate props?? >
Old 08-03-2005 | 10:59 PM
Default Awesome 26 with twins - Which way do I rotate props??
I have a 26 ft Awesome Powerboat - true cat without the center pod. It has twin 225 outboards on it and lower units are lh/rh. Problem is, which lower unit should go on which side?? I see the clockwise unit on the right on most setups but I have been told to run opposite and have props rotating inboard for better lift on this boat. Any advice??
Also, what is the tiny hose fitting when the lower unit is removed just in front of the shifter spline? I ramoved it and it just seems like a cavity going nowhere. I do have modified lowers with nose cones and low water pickups. It seems this cavity does not go to the gearcase or the water passage. Any help?? Thanks so much!!!
JWScarab is offline
Old 08-04-2005 | 11:10 AM
Brad Zastrow's Avatar
Default Re: Awesome 26 with twins - Which way do I rotate props??
I have owned a number of o/b twins on cats. I like turning the props in. (top of the blade turns in). Turning in is usally a little faster with less porpoise. Turning out will handle better and feel more glued in. Every boat is different. Props, engine height, rotation are setup issues that can make a lot of difference.
The nipple is probably the old speedo pickup that is built into the front of the lower unit. Since you have an aftermarket nose cone covering that, it is no longer functional.
Brad Zastrow is offline
fastmcars
05-07-2008 07:49 PM
Jassman
Active Thunder
11
09-04-2007 02:47 PM
craig pogue
05-31-2007 12:04 PM
Buddy OO
06-03-2006 04:05 PM
offthefront
3
02-28-2004 09:38 AM
