Hyd. roller lifters Gen 6 >
Old 08-04-2005 | 03:12 PM
KCHOTBOAT's Avatar
Charter Member #737
Default Hyd. roller lifters Gen 6
I am on my third trip to the parts store getting lifters. Made two calls to crane and got three set of part numbers that where wrong. Two which ended up being solid lift roller.
Does anyone have a part number for a HYD. roller lifter set?
This is for a Gen 6 block. The set that came with the comp set I bought through CP they tie bars bottomed out on the block.
KCHOTBOAT is offline
Old 08-04-2005 | 03:40 PM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: Hyd. roller lifters Gen 6
Has anyone used Lunati roller lifters?
Old 08-04-2005 | 03:58 PM
Did you try 13532-16 ?
These have the tie bar between them.
I used these on My gen 6 HP500's this spring.
JaayTeee is online now
Old 08-04-2005 | 08:01 PM
Don't laugh but the most reliable lifter for that block, and for marine use is the STOCK G.M. lifter trust me I will only use this lifter with my gen 6, I run ultradyne cams at 6100 RPM naturally aspirated 1271 cfm carbs in a 40 ft cat, runs strong at 110 mph, never a lifter problem. ( any G.M. Dealer will get them)
abones is offline
Old 08-04-2005 | 09:00 PM
KCHOTBOAT's Avatar
Charter Member #737
That is the same thing Comp cam tech line told me today. I have the stock ones and will see if they work. This cam came out of my 540 and when I built it the kit that CP performance sold me came with lifters because they told me the stock one would not work. When I called last week for the springs that said the came is a gen 6 and now I looked up the cam number and it comes up with this for years.
Part Number 11-775-8
Engine 1965-1996 Chevrolet
396ci-454ci
8cyl.
Grind Number CB XR271HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.591 0.601
Duration At 0.006 Tappet Lift 271 279
Valve Timing At 0.05
Open Close
Intake 1 41
Exhaust 49 1
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 222 230
Lobe Lift 0.348 0.354
Lobe Separation 112
Old 08-04-2005 | 11:46 PM
Wink Re: Hyd. roller lifters Gen 6
You should talk to Rpmbuilder here on OSO. He sells the Morrel lifters, which I understand are stronger than the stock GM hydraulic roller lifters.
Ray @ Raylar
Raylar is offline
Old 08-05-2005 | 08:25 AM
Nordicflame's Avatar
Crane 16535-16 is the lifter set for the GenVI block, You use the existing dog bone retainers and they will accept much higher lifts and rpms. I run a 168741 cam (.632 lift) and still have tons of travel left. Very dependable and have been flawless in several high hp applications for the last several years with no failures what so ever. RPMs around 6000 in my applications. Probably close to the limit with hydraulics.
Down side is cost (~$425)
The stock lifters drop into the retainers too far at over .575.
Hope this helps,
Dave
Nordicflame is offline
Old 08-05-2005 | 08:36 AM
KCHOTBOAT's Avatar
Charter Member #737
Hope this helps,
Dave
I put in the stock ones last night and they drop down into the retainers.
Old 08-05-2005 | 08:47 AM
Yes, too risky.
You'll be happy with the Crane lifters.
Old 08-05-2005 | 08:51 AM
KCHOTBOAT's Avatar
Charter Member #737
Just checked the price on Jegs they are not cheap $549.99.
