cam size
How do these cams specs look for a 468, stock heads and 525SC blower/wieand 177? Comp tech line told me the cam was for a gen 6 which I had the cam in my 540 which was a mild motor. Since I have the cam looking to save a few bucks.
Also would I run into problems running stock lifters since finding aftermarket ones had been a real problem.
Part Number 11-775-8
Engine 1965-1996 Chevrolet
396ci-454ci
8cyl.
Grind Number CB XR271HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.591 0.601
Duration At 0.006 Tappet Lift 271 279
Valve Timing At 0.05
Open Close
Intake 1 41
Exhaust 49 1
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 222 230
Lobe Lift 0.348 0.354
Lobe Separation 112
396ci-454ci
8cyl.
Description
Intake Exhaust
Open Close
Intake 1 41
Exhaust 49 1
Intake Exhaust
Lobe Separation 112
nova26
41
07-07-2008 06:10 PM
