need prop advise >
need prop advise
need prop advise
Old 08-05-2005 | 03:21 PM
grimmy's Avatar
Default need prop advise
i have a 1993 cig top gun with merc 425hp motors, trs drives, 21p three blades, dose 60mph gps at 5100 rpm, i need a second set of props and want to get a set that will give me best top end. what do i get for this pig? any help would be great. what set ups do you all run?????????? http://powerboatlistings.com/view/2085.
Attached Thumbnails need prop advise-c1.jpg   need prop advise-c6.jpg   need prop advise-c9.jpg
grimmy is offline
Old 08-06-2005 | 10:16 AM
grimmy's Avatar
Default Re: need prop advise
thanks brother, what pitch???????????
grimmy is offline
Old 08-07-2005 | 10:36 AM
grimmy's Avatar
sweet, sounds good so far, what speeds do you see with what motors, and can my 425hp push these as well?
grimmy is offline
Old 08-08-2005 | 10:29 PM
POOL WHORE's Avatar
Grimmy
Are you coming out West for the Poker Run? I will let you try a set of stocker 23P Mirage props. They should work great for fresh water low swell application.
Hugh
POOL WHORE is offline
Old 08-08-2005 | 10:34 PM
grimmy's Avatar
i'm in vegas and i'd love to if it isn't sold first. when and where can we hook up, i also need someone to show me the ropes out on the salt h2o. lets go have lunch and a cold one on me. thanks for the offer
Attached Thumbnails need prop advise-c1.jpg   need prop advise-c2.jpg   need prop advise-c42.jpg
grimmy is offline
Old 08-08-2005 | 11:45 PM
POOL WHORE's Avatar
Grimmy
I am usually lurking around The Dunes in Newport. A few of us ran this weekend. The water was very flat and the speeds were high. We ran from Newport to Long Beach, which is around 25 miles, hard. I was at 4700-5100 RPMs the whole trip up and back. Less than 3 weeks til the SCOPE Run.
Hugh
Old 08-08-2005 | 11:52 PM
grimmy's Avatar
i tried for 4th of july, but EC Marine had the boat all week for 100 hr tune. love to do yardhouse before my boat is gone, shes not fast but she seems to get me there every time, wanta plan something???????????????Robert
Attached Thumbnails need prop advise-c1.jpg   need prop advise-c2.jpg   need prop advise-c6.jpg
grimmy is offline
Old 08-09-2005 | 12:02 AM
POOL WHORE's Avatar
I am always up for running! The Yard House is a great place to check out some HOT offshore boats. Slip space is limited to around 24, so arrive early. The docking is tight for a 38 footer, but there are dock hands to assist.
I am dropping of the boat at Pfaff in the morning for fluid change and check up. I should be ready for the weekend. Maybe some performance mods? Definately going 20-21 and poker run.
Hugh
frankm7
6
12-12-2003 07:45 AM
Ran-Dom 32
05-14-2003 05:16 PM
BAJA WILL
04-28-2003 11:27 AM
wes29
Powerquest
6
10-17-2002 05:57 AM
