emergency engine hatch access? >
Old 08-07-2005 | 11:17 AM
Default emergency engine hatch access?
The batteries on my 1999 342 Boss are dead and the engine hatch is closed. Anyone know if there is an emergency access hatch so I can get at the batteries to charge?
Thanks!
342boss is offline
Old 08-07-2005 | 11:46 AM
cuda's Avatar
Default Re: emergency engine hatch access?
I'm not sure on your boat. Some are made where you can lift the hatch manually far enought to pull a pin to disconect the hatch, others have a set of leads to the battery under the rear seat. Seems my buddy had the leads in his Baja.
cuda is offline
Old 08-07-2005 | 01:25 PM
Pwrbt33's Avatar
Talking Re: emergency engine hatch access?
Do you have a cigarette lighter socket on board? Get an adapter of some sorts and cut the opposite end off, plug the good end into the cigarette lighter and the wires to the appropriate side of a jumper boost back, extra battery or a battery charger. Then raise the hatch.
John
Pwrbt33 is offline
Old 08-07-2005 | 05:41 PM
Thanks - appreciate the help. This is what I did and the problem was solved easily.
342boss is offline
Old 08-07-2005 | 09:39 PM
Pwrbt33's Avatar
Good to hear !!!!
Pwrbt33 is offline
Old 08-07-2005 | 10:28 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Now think of a plan if the lift were to go bad.
US1 Fountain is offline
Old 08-07-2005 | 11:01 PM
Shorepower Plug In If You Have It!!
32 thunder is offline
Old 08-08-2005 | 08:34 AM
jdnca1's Avatar
Pull the hinge pins and lift it manually from behind, then squeeze in and pull the pin on the acuator. (assuming you have access to the hinge pins)
jdnca1 is offline
Old 08-08-2005 | 08:41 AM
cuda's Avatar
Which way did you do it?
cuda is offline
Old 08-08-2005 | 05:41 PM
dtsquest's Avatar
On my Powerquest I can lift the hatch manually if the battery is disconnected. I figured that out while removing the batteries for winter storgae. Just get your hands under the hatch, and lift.
dtsquest is offline
