Will oil in transom cause rot or not? >
Old 08-10-2005 | 12:00 AM
phughes69's Avatar
Default Will oil in transom cause rot or not?
When I was getting my boat ready for the year last year I had to bleed the trim tabs because one of them would not hold pressure. I found oil coming out thru the top of the transom on the inside. One of the hydraulic transfer tubes (Aluminum) for the trim tabs ( K planes) corroded away and was leaking oil into the transom. Would this cause the transom to rot? What should I do about the transom? I replaced the tubes with a stainless one and the holes that did not have the coroded tubes were dry.
phughes69 is offline
Old 08-10-2005 | 05:34 AM
Official OSO boat whore
Default Re: Will oil in transom cause rot or not?
If oil got in there, then moisture can too. Where wood and moisture come in contact, the wood will rot.
Cord is offline
offshoreratboy
Detailing, Painting, & Fiberglass
134
06-26-2014 11:01 AM
Sick Stinger
08-28-2008 03:36 PM
justice
Cigarette
37
06-11-2008 05:24 AM
Courtholl
Pantera
0
08-08-2005 09:59 AM
cowisl
5
04-29-2004 03:47 PM
