Searching - Used 502 out there?
Originally Posted by Shooter
just for the helluvit what are you asking for it?
MSD complete marine system
Deluxe Ignition Package
"Deluxe" MSD / Hardin Ignition Package - Chevy V8
(1) Billet Marine Distributor
(1) MSD 6-M Series Multi-Spark Ignition Control Box
(1) High Vibration Coil
(1) Soft Touch Ignition Rev Control
(1) Deluxe Polished Stainless Steel Cylinder Head Mounting Bracket
(1) Custom Fit 8 MM Heli-core Spark Plug Wire Set
(1) Red Billet dist. hold down and stud
The Motor,Long Block
Gen VI four bolt main block, with forged pistons, forged 4340 steel connecting rods with 7/16" bolts, a 1053 forged steel crankshaft , Blue printed high volume oil pump , Dually 10 qrt. with windage tray and scrapper , Comp Cams XR300 Hr Hyd. roller cam shaft Exh. lift .254 / .580 Int. lift .248 / 560 , roller Lifters ,Comp Cams SST roller rockers, Comp cams stud girdeles, pushrods Complete valve train . Comp Cams true roller timing set ,Edelbrock 6045 alum heads ported and polished by R&R Machine In Napa Ca,Stainless steel 2.19" intake and 1.88" Polished alum. timing cover , polished alum. crank pulley , SFI approved flex plate.Aluminum exhaust with center risers,Edelbrock single plunum manifold.
Originally Posted by wkd1
$6000.00
looking for stock only. Hey if that were the case I got two for sale with the boat. Ebay gives me the heebee geebees. I buy and sell lots of small computer stuff. I'd be afraid of a ripoff.
