525SC lifters and valve springs >
Old 08-11-2005 | 06:33 PM
dykstra's Avatar
Question 525SC lifters and valve springs
Any suggestions for lifters and valve springs. I am ordering the stock cam. Crane#132561.
dykstra is offline
Old 08-12-2005 | 09:29 AM
dykstra's Avatar
Default Re: 525SC lifters and valve springs
ttt
dykstra is offline
Old 08-12-2005 | 10:57 AM
PatriYacht's Avatar
Just order the stuff that Crane reccomends. I had the same cam in my Cyclone 400s for 11 years and 600+ hours with no problems whatsoever. Be careful at cam breakin time. DO NOT IDLE FOR THE FIRST 20 MINUTES.
PatriYacht is offline
Old 08-12-2005 | 02:25 PM
I agree to ensure your self the breakin is going right crack the valve covers loose and make sure your pushrods are all turning do this by marking the pushrod with white marker if all the pushrods are turning it will last for ever if you have any that don't turn stop because it will scrub the lobe and you'll have to start all over again. Good luck to you.
MESABALANCING is offline
Old 08-13-2005 | 08:29 AM
dykstra's Avatar
Thanks for the info. Crane recommends #99277-16.
dykstra is offline
C_Spray
5
11-29-2007 11:04 AM
mr_velocity
1
02-10-2005 12:32 PM
BAJA WILL
5
07-21-2003 01:16 PM
BAJA WILL
04-10-2003 09:32 PM
