v6 module ?s >
v6 module ?s
v6 module ?s
Old 08-14-2005 | 03:56 PM
redfountain420s's Avatar
Default v6 module ?s
I just got my boat together, the motors are hp500 efi long blocks with 420 mega blowers and 4-750holley--nickerson carbs with v6 modules.
when i set the total advance at 30 degrees and shut the motors off , it is hard to start- slow cranking.
what is the cure ? if i back up the timing it cranks right over
thanks for any help you can give
kevin
redfountain420s is offline
Old 08-14-2005 | 03:57 PM
JCPERF's Avatar
Default Re: v6 module ?s
kevin
What starters?
JCPERF is offline
Old 08-14-2005 | 04:13 PM
i have the trs outdrives so the starters mount on top fromthe back and they were both rebuilt before installed they look like a international starter
Old 08-14-2005 | 04:19 PM
heres a picture
Old 08-14-2005 | 04:33 PM
JCPERF's Avatar
You might have to put the Merc starters on your engines.They turn over fine with the v6 modules.Check your grounds too.
JCPERF is offline
Old 08-14-2005 | 08:10 PM
mtgbiker's Avatar
kevin
Kevin,
Great to hear you have em' together. I'm looking forward to hearing from you on the cell phone when your on the lake in the 42!
Dan
mtgbiker is offline
Old 08-14-2005 | 08:37 PM
kevin
I also think the starters could be the problem, I had a checkmate with a 400 cyclone series 454 with a blower and the v-6 module, merc starter turned it over fine for many years, I believe the V-6 only has 16 degrees advance buit in so your base timing should be around 14 to 15 BTDC requires more torque to crank, V8 module has 24 degrees built in base timing much lower. but wrong for a blower
abones is offline
tjsmk8
5
07-23-2007 08:03 AM
Corsa 31
11
01-10-2005 02:50 PM
TROUBLE MAKER
15
07-28-2004 07:00 PM
kennyo
0
03-08-2004 08:36 AM
