Water Leak - Thru hull water pick ups >
Old 08-15-2005 | 10:36 AM
waterbum's Avatar
Default Water Leak - Thru hull water pick ups
I finally found the source of my small water leak. While under way at more than idle speed, water seems to be coming up through the hull water pickup. I looked under the boat while it was on the lift and it looks like the tubes start about 1/8" up the holes. This leaves a small amount of exposed glass before the tubes start. I assume water is going up outside the tubes. The right way to fix these would be to remove the pickups from inside the hull, and reseal them. To do this I would have to remove the inside headers (removing 1 engine would make it very easy). Is there anything I can do temporarily until the end of the season to slow down the water intrusion? Maybe single layer of glass around edge? Would that disrupt the water flow? Or should I go ahead and take the time to fix these correctly?
Thanks,
Doug
waterbum is offline
ROTAX454
Skater
28
01-10-2008 04:26 PM
cougarman
12-05-2006 02:21 PM
Maximus
04-30-2004 06:29 PM
enticer
2
09-15-2002 06:13 PM
beerock
07-03-2002 06:37 AM
