NEW Victory 'Rage' trim tab...prototype >
Old 08-15-2005 | 11:17 AM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Default NEW Victory 'Rage' trim tab...prototype
I've been having some fun lately in the 'trim tab lab'. This is just one direction the Victory lineup will be taking.
Specs:
- 14" x 24"
- unique standoff brackets (of course I can also provide a generic backing plate if desired)
- 100% stainless steel, no dissimilar metals
- plastic inserts avail. in many colours (+ LOW drag coefficient ) This plastic plate can also be 'stepped'
- dual electromechanical actuators w/ stainless sleeves (each actuator can exceed 2000lb. downforce )
- braided stainless steel wire sheath (elec. cable can also be hidden inside standoff bracket by rotating actuator, if desired)
- mirror polished VICTORY logo recessed into tab ('raised' version too!)
- fully polished stainless hardware
- unique 'mini-tab' switch or standard rocker
- 10-bar LED indicator guage fits into standard 2 1/16" hole (stainless or black bezel)
- wild powdercoat finish w/ clear pc topcoat
---60% sparkle silver
---40% candy blue
---crystal clear powder topcoat
When 'off-the-shelf' doesn't do it for you call MARTINIBOAT. Factory direct prices + you can join in the design process! We create projects that are as unique as the boats they're mounted to!
Attached Thumbnails NEW Victory 'Rage' trim tab...prototype-rage5.jpg   NEW Victory 'Rage' trim tab...prototype-rage2.jpg   NEW Victory 'Rage' trim tab...prototype-rage8.jpg
Last edited by martiniboat; 08-20-2005 at 07:22 PM. Reason: forgot an important spec.
martiniboat is offline
Old 08-15-2005 | 11:24 AM
Milord's Avatar
Default Re: NEW Victory 'Rage' trim tab...prototype
Very cool Brian, those look wicked!
Milord is offline
Old 08-15-2005 | 11:39 AM
Here's another surprise!
THE VICTORY AUTOSET + the 'MINI-TAB' switch
- 12 or 24 volts DC
- built-in LED tab indicators (top LED flashes when tabs are in full-up position)
- 6 presets (when you find the 'sweet spot' at ANY given speed it's easier than ever to duplicate your settings )
- display can be dimmed at night @ 4 different intensity levels
- upper key 'tabs up' brings both tabs to the top + a two second overrun to synchronize the tabs and microprocessor.
- center #2/5 buttons actuates tabs up/down simultaneously
- #1/4 and #3/6 operate tabs individually
- auto-retract feature at shutdown
- will also accept up to 2 manual remote switches!
At MARTINIBOAT you can have it your way!
Attached Thumbnails NEW Victory 'Rage' trim tab...prototype-vic-autoset1-small.jpg   NEW Victory 'Rage' trim tab...prototype-vicswitch1-small.jpg   NEW Victory 'Rage' trim tab...prototype-vicswitch2-small.jpg
Old 08-15-2005 | 11:42 AM
more 'Rage'...
Attached Thumbnails NEW Victory 'Rage' trim tab...prototype-rage3.jpg   NEW Victory 'Rage' trim tab...prototype-rage4.jpg   NEW Victory 'Rage' trim tab...prototype-rage7.jpg
Old 08-15-2005 | 11:44 AM
and finally...
Attached Thumbnails NEW Victory 'Rage' trim tab...prototype-rage6.jpg   NEW Victory 'Rage' trim tab...prototype-rage8.jpg   NEW Victory 'Rage' trim tab...prototype-vicswitch3-small.jpg
Old 08-15-2005 | 11:53 AM
Thanks James!
I'm working on a different version as we speak. One that will be finished in (naked) stainless that I've dubbed the 'psycho swirl' It is a multi-directional masterpiece coated with a crystal clear powder.
Enjoy, my friends.
B
Old 08-15-2005 | 06:48 PM
fruitta55's Avatar
Those look sweet! Will you be offering different color metalwork on them?
And that Autoset thing is just crazy. Talk about making triming easy!
fruitta55 is offline
Old 08-15-2005 | 06:50 PM
FASTTIMES's Avatar
Very Nice!!! and the pre-sets are innovative- - Keep up the nice work!
FASTTIMES is offline
Old 08-15-2005 | 07:54 PM
Thanks guys,
I will be offering virtually any colour you can imagine for the powder coated stainless metalwork, your imagination is my template. The plastic bottom plate and contrasting inserts will be available in red, white, blue and yellow.
Mix n' match my friends, mix n' match ...
Old 08-17-2005 | 12:14 PM
The business end.
Not much room for my steering, coming soon...
File Type: jpg
martiniboat
06-02-2018 09:16 AM
Whassup
4
02-12-2008 11:21 PM
Rage
Nordic
16
06-27-2006 08:31 AM
martiniboat
04-06-2005 06:39 AM
martiniboat
11-10-2004 01:05 PM
