How much Drive oil? >
How much Drive oil?
How much Drive oil?
Old 08-16-2005 | 07:14 AM
Stormrider's Avatar
JC Performance Engines
Default How much Drive oil?
How many quarts of oil do I need to change my drive oil?
Bravo 1.
Stormrider is offline
Old 08-16-2005 | 07:54 AM
Chris288's Avatar
Default Re: How much Drive oil?
I usually use a clamp on the hose from the resevoir bottle as far toward the transom/drive as possible, no need to waste all that oil. then is usually a bit less than 2 quarts.
Chris288 is offline
Old 08-16-2005 | 09:12 AM
East Coast B's Avatar
My manual says two quarts... I was just going to post a question regarding drive oil....
I noticed that penzoil sells a 80w-90 gear oil for automotive rears and has the same sae-5 rating or something like that as does the marine outdrive oil... Is this the same stuff, but at just half the cost of the marine version??
East Coast B is offline
Old 08-16-2005 | 09:27 AM
Wobble's Avatar
SORE MEMBER
Bravo-1 takes about 2 and 2/3 quarts. If it is completly empty.
I ran the Redline heavy shockproof for 50 hours, am trying the Mobil-1 75w90 synthetic. The Redline takes forever to drain and can be messy, so I am trying the M-1 which seems to be popular here.
Wobble is offline
Old 08-16-2005 | 09:30 AM
Are the redline and mobil specific to marine use or are they automotive gear oil?
Old 08-16-2005 | 09:32 AM
Stormrider's Avatar
Dunno, I'm just using quicksilver HP gear lube.
Old 08-16-2005 | 09:42 AM
Wobble's Avatar
SORE MEMBER
Not specified for that use, but a lot of members are using them with good results. The main thing I noticed with Redline is that the magnet on the drain plug had much less metal on it compared to Merc HP thru 2 x 50 hour changes. The main thing to consider before switching is to make sure your drive has good sealing as these oils may not handle water contamination as well as Merc HP. Hydrocruiser has not been able to find the specs on Merc HP gear oil. Wheras the M-1, Redline, Alisyn specs are well known.
Wobble is offline
Old 08-16-2005 | 11:21 AM
GOODT's Avatar
2.8 Qts Plus The Res!!!
GOODT is offline
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
jeff32
06-28-2006 08:48 AM
DrNautica
21
04-03-2005 08:57 PM
Velocity Tom
07-16-2003 10:13 AM
HyperBaja
04-20-2003 05:39 PM
