power steering pump >
power steering pump
power steering pump
Old 08-16-2005 | 02:55 PM
Dono's Avatar
Default power steering pump
What type of lube goes in here? I have mayfair external steering. Also I have a marine machine resivoir that runs over to my powersteering pump. I had to disconect the hose in order to pull the motor out and red fluid came out kinda like trans fluid. I put it all back together and need to top off the resivior. Also do i need to bleed the system? I didnt let all the fluid run out but what if air got in? Thanks.
Dono is offline
Old 08-16-2005 | 06:38 PM
ratman's Avatar
Default Re: power steering pump
i run atf in mine. i think if you fill it up and keep cycling up and down it will bleed itself
ratman is offline
Old 08-16-2005 | 09:50 PM
Dono's Avatar
thanks, i thought it looked like atf and not powersteering fluid.
Dono is offline
Old 08-17-2005 | 01:12 PM
Dave M's Avatar
Veteran: Navy
I use ATF too.
Dave M is offline
Old 08-17-2005 | 04:37 PM
hillbilly24's Avatar
just make sure you don't use type F it will destroy the pump and the seals in the steering clyinders.
hillbilly24 is offline
jbrauer
04-23-2015 12:24 PM
Run_em_hard
05-27-2008 02:34 PM
Revd Up
5
07-01-2007 01:03 AM
Johno
4
06-30-2003 05:21 PM
