idle mixture for dominator carbs >
Old 08-18-2005 | 10:33 AM
ratman's Avatar
Default idle mixture for dominator carbs
what should the base line be for # of turns out on the idle mixture screws? in is leaner correct?
ratman is offline
Old 08-18-2005 | 11:26 AM
Default Re: idle mixture for dominator carbs
Start at 1 1/2 on primaries, and about 3/4 on secondaries.
In is leaner.
Gary Anderson is offline
Old 08-18-2005 | 11:51 AM
mopower's Avatar
Toxic FORMULA
Mine are 3/4 around
mopower is offline
Old 08-18-2005 | 01:40 PM
ratman's Avatar
which are the primaries? the butterflys all open at the same time.
ratman is offline
Old 08-18-2005 | 01:45 PM
Are you sure? Is it a blower carb?
Anyway, I started 1 1/2 out ended up with abot 1 on primaries and less than 3/4 on secondaries.
Old 08-18-2005 | 05:17 PM
ratman's Avatar
single 1050 dominator on a n/a 577ci eng. just looking for a base line adj for the idle circuit mixture
ratman is offline
Old 08-18-2005 | 06:35 PM
DanB's Avatar
Charter Member #71
1 1/4 turn out ea.........then use a vacum gauge
DanB is offline
Old 08-18-2005 | 08:29 PM
ratman's Avatar
dan i have a vacuum gauge do i tune it for the most vacuum?thx, ratman
ratman is offline
Old 08-18-2005 | 08:36 PM
articfriends's Avatar
Tune for theb most vacum then go 1/4-1/2 turn richer. Motor should then start when its hot by just hitting key,Smitty
articfriends is offline
Old 08-19-2005 | 02:06 PM
DanB's Avatar
Charter Member #71
Phil
I left you a voice mail on the phone # you sent me. Your PM box is full!!!!! empty it
Dan
DanB is offline
