fuel pressure gauge stuck to far right >
Old 08-21-2005 | 09:45 PM
Default fuel pressure gauge stuck to far right
stuck fuel pressure gauge pegged to far right. disconnected from sensor no change. any idea? Thanks
customryder is offline
Old 08-21-2005 | 10:46 PM
Default Re: fuel pressure gauge stuck to far right
thanks Fred! Jeff
Old 06-27-2006 | 10:00 PM
same trouble on different boat, swapped sender no change... fred?
Old 06-28-2006 | 12:18 AM
Strip Poker 388's Avatar
Rob
sounds like the ground wire loose???
Strip Poker 388 is offline
Old 06-28-2006 | 02:22 PM
Grog's Avatar
Assuming it is an electric gauge, it will read an open circuit like that. I would check wiring and connections for continuity between gauge and sender.
Grog is offline
Old 06-28-2006 | 08:21 PM
RedDog382's Avatar
Going with Strip on this one. ground.
RedDog382 is offline
Steve_H
4
02-03-2007 11:58 PM
bcarpman
18
01-20-2007 05:55 PM
activox
07-27-2005 01:56 PM
DORaymond
2
06-01-2005 03:00 PM
mats
2
05-05-2003 04:59 AM
