Back flushing motor procedure? >
Old 08-31-2005 | 12:43 AM
Kokopelli's Avatar
Default Back flushing motor procedure?
2000 502 MPI - What's the best / easiest way to do this?
Kokopelli is offline
Old 08-31-2005 | 04:13 AM
East Coast B's Avatar
Default Re: Back flushing motor procedure?
Not sure by your post as to exactly what your trying to achieve.... but I'm thinking that you might be trying to backflush out missing impeller pieces??? Other obstructions???
There were several posts just recently which go more into depth.. but to get you started if impeller pieces are the issue....
Remove front and rear hoses of oil cooler. In the aft of the oil cooler, feel around for impeller pieces, if you don't find all that you are missing, flush water through front of oil cooler, then recheck aft of oil cooler again. If you look at front of oil cooler, holes are so small, most pieces of impeller will never get past oil cooler and if they do, they are so small, they will get exhausted out.
If this isn't what your looking for, post more details....
Good luck!
East Coast B is offline
Old 08-31-2005 | 08:21 AM
Kokopelli's Avatar
Thanks ECB - exactly what I was looking for. I think I got all the pieces, just want to be sure.
articfriends
71
09-30-2011 03:07 AM
cloudmaster_321
12
10-13-2008 02:00 PM
nocigarette
Magnum Marine
2
08-28-2006 06:35 AM
Chris288
16
08-20-2006 11:11 PM
mxz800
1
06-09-2002 09:16 AM
