Dana Marine Exhaust - New Lower Pricing
With a new run on manifolds and risers we've decided to adjust our retail pricing. Here we go,
Manifolds with Aluminum risers $1195.00 pr
Manifolds with Stainless Steel Risers $1695.00 pr
You Choose POLISHED or HARD ANODIZED W/ POWDERCOAT
NO HIDDEN FEES @ DANA MARINE
www.danamarineproducts.com
Custom tail pipes are available, need o2 sensor fittings? No problem, Custom tail pipe configuration? No problem. If one of our standard kits won't work, give us a call.
Thanks Brian, It's nice to hear compliments. Beside this system being the best looking manifolds on the market, they have four individual big I.D. runners that run all the way through the flange, no other system has that feature. These manifolds make good HP on all engine applications. There's some "So Called" performance manifolds out there that don't work much better than stock Mercruiser cast iron manifolds. DMP exhaust look awesome and make good HP.
DMP Vortech Stainless Steel Risers offer an internal vortex cone for optimum exhaust scavenging. With this system you have a 27" long primary runner. A standard "E" tube header system has a 15 1/2" primary runner. This results in better response and performance throughout the range. Vortech riser options are available for an additional $150.00.
Hi Gary, we've discussed this two or three times now and we've apologized for the inconvenience. Unfortunately you did not receive the proper stainless bolts. We've offered to pay you back, or to issue you a store credit for any future needs. I know it's not about the money, that's why I've offered, it's about making things right.
Just put two sets on my boat. Ordered them recommended by Fred. They look and work great. Also, they had to make two custom risers, they did this quickly and perfectly. Thanks again, Eric
Hi, the brackets are sold separate. We don't include them beacuse most customers don't order them. The shift brackets are $35.00 each. We don't offer an off the shelf oil filter bracket.
