Need advice on gauges. >
Old 09-02-2005 | 09:31 AM
Donman's Avatar
Default Need advice on gauges.
After my engine failure, due to a faulty/weak fuel pump (leaned out), I am installing a fuel psi gauge on my dash. I know how to connect this one, but I`d also like to install an oil temperature gauge and water pressure gauge.
Where do you plumb in the oil temp gauge? Same place as oil psi gauge?
And...I have absolutely no idea where / how to connect water psi gauge....please advise.
Donman is offline
Old 09-02-2005 | 11:11 AM
monstaaa's Avatar
Default Re: Need advice on gauges.
water psi should goin the blockdrain on either side of the block.
plumb oil temp in before cooler, there is a spot on the remote filter housing.
monstaaa is offline
Old 09-02-2005 | 12:44 PM
Lofty's Avatar
Ever consider EGT's? Sure would let you know immediately when you are getting a lean condition. Like ALL guages, they are only any good if you observe them.
Lofty is offline
Old 09-02-2005 | 01:54 PM
Donman's Avatar
EGT gauge. OK, I`m game. Great idea! So where does this plumb in?
Donman is offline
Old 09-02-2005 | 02:19 PM
Lofty's Avatar
You have to... are you ready for this! Drill into your exhaust! If you have headers you'll need to send them in and have some bungs welded in.
Lofty is offline
Old 09-02-2005 | 02:44 PM
biginches's Avatar
for the block drain put in a tee and put drain back in.
if water freezes in pressure line you'll be buying a new gauge
biginches is offline
Elite Marine
Baja
5
03-16-2008 07:58 PM
thedonz
12-29-2005 10:34 AM
fishead
12-08-2005 01:03 PM
Ric232
4
05-17-2003 08:01 PM
Steve A.K.A RAMPAGE
4
04-24-2003 07:35 AM
