vent tube relocation? >
Old 09-08-2005 | 08:55 AM
Question vent tube relocation?
I swapped a stock weber carb with a nickerson/holley carb and I'm not sure where the fuel pump vent tube should be relocated. The weber has provisions for the tube, but does the holley?
yadamnright is offline
Old 09-08-2005 | 09:12 AM
Wobble's Avatar
SORE MEMBER
Default Re: vent tube relocation?
Most Holleys don't. I installed a fitting in the air cleaner housing that will dump fuel into the venturi in the event that the pump seal fails. Do not use any of the ports on the side or base of a Holley for this as it could mess up your carb calibration by allowing air to be sucked thru the pump.
Wobble is offline
Old 09-08-2005 | 12:14 PM
RedDog382's Avatar
Some aftermarket flame arrestors (Gaffrig) have a nipple on them to attach it to.
RedDog382 is offline
Old 09-08-2005 | 11:22 PM
Nickerson's did my carb...great job. As RedDog said Gaffrig arrestors have a nipple to stick the line on, at least mine does.
Kidnova is offline
Old 09-09-2005 | 07:30 AM
Thumbs up Re: vent tube relocation?
Thanks for the replies. I'm using a K&N spark arrestor so I'll have to fabricate a fitting that will return the fuel back to the carb.
Old 09-09-2005 | 07:45 AM
mopower's Avatar
Toxic FORMULA
K&N does sell such a part if you check it out
mopower is offline
razor1115
2
03-22-2008 10:04 AM
anotherdimension
01-20-2007 09:01 AM
voodoo
07-30-2004 04:08 PM
kaamacat
5
07-26-2003 10:51 PM
