OK, I got the gauges, now what should they read? >
Old 09-10-2005 | 03:34 PM
Donman's Avatar
Default OK, I got the gauges, now what should they read?
I`ve got the engine out now and have purchased fuel psi gauge, oil temp gauge and water psi gauge.
I know what my fuel pressure should read, but what is normal reading for OIL TEMPERATURE? What is the range, when is it hot enough to hammer throttles and at what temp is danger zone?
OK...what should my water pressure read at idle and what is normal at cruise speed (3500 rpm) and what is normal at WFO (5500-5800 rpm) ?
Donman is offline
Old 09-10-2005 | 11:06 PM
Default Re: OK, I got the gauges, now what should they read?
You want oil temp to get up to 212* to burn off any condensation in the oil at some point. Over about 260* would be too HOT.
H20 pressure is only a couple lbs at idle. At WOT, you do not want it over 25 lbs. 15lbs at WOT is plenty.
Griff is online now
Old 09-15-2005 | 10:12 PM
Mudball's Avatar
Yup, Griff is perfect on this!!
Hey HP, is that really you, alias Donman somewhere else?
Mudball is offline
barron
Fountain
0
01-01-2007 08:31 AM
TeamSaris
12-03-2006 05:42 PM
Formula29
4
10-07-2004 02:10 PM
Steve A.K.A RAMPAGE
4
04-24-2003 07:35 AM
88 MACH 1
5
10-15-2002 08:06 AM
