where is the Orofis valve in hydraulic steering? >
Old 09-12-2005 | 01:28 PM
magnum27's Avatar
Default where is the Orofis valve in hydraulic steering?
I have read about drilling out a valve to make hydraulic steering work properly but do not know where this valve is and how much bigger does the hole need to be?
magnum27 is offline
Old 09-12-2005 | 01:53 PM
birdog's Avatar
Default Re: where is the Orofis valve in hydraulic steering?
Not a valve, Just the hole on the Pres. side.....11/64s per Imco
birdog is offline
Old 09-12-2005 | 03:23 PM
Wobble's Avatar
SORE MEMBER
It's in the fitting that holds the high pressure line on the back of the power steering pump (banjo type fitting). They should have sent you instructions on how to do that to increase flow.
Wobble is offline
Old 09-12-2005 | 03:36 PM
Dave M's Avatar
Veteran: Navy
Just curious, why does this need to be done. I did not do it and my steering works fine.
Dave M is offline
Old 09-12-2005 | 04:53 PM
bglz42's Avatar
Just don't accidently plug the little hole on the side of the fitting. If you do... no power steering! Ask me how I know that..
bglz42 is offline
PARADOX
09-06-2007 06:46 PM
26sonic
Sonic
1
05-03-2006 10:09 PM
Whiteknuckle
49
12-07-2005 07:16 PM
chewy1955
3
06-18-2004 09:55 PM
CHAOS REIGNS
5
12-11-2002 07:56 PM
