Neutral saftey switch problems >
Old 09-20-2005 | 12:03 PM
JasonSmith's Avatar
Default Neutral saftey switch problems
I have Gaffrig controls and have not opened them up before. Before I do is the nuetral saftey switch located with the shift levers or somewhere else?
JasonSmith is offline
Old 09-20-2005 | 12:33 PM
Default Re: Neutral saftey switch problems
It's in the shifter portion of
the throttle/ shift quadrant.
JaayTeee is offline
Old 09-20-2005 | 04:26 PM
JasonSmith's Avatar
Hard/time consuming fix?
Old 09-20-2005 | 04:53 PM
Take out the 4 screws that hold in the
throttle/shift quadrant, then lift it out.
You'll see 2 small switches that are
activated by the shift levers.
I don't recall how the switches were fastened.
Worst case, you may have to split the sections
of the quadrant to gain access to the screws.
If you have to do that, you may want to disconnect
the cables and wiring and remove it for disassembly
( so your not dropping pieces down through where the
quadrant mounts )
I had gaffrig controls on my old boat, and the only
starting problem I had with it was caused by a faulty
slave solenoid back at the engine.
JaayTeee is offline
Old 09-20-2005 | 05:08 PM
GOODT's Avatar
be careful as there are little detent balls and srings in there that will fall out when you take a part
GOODT is offline
86formula242ls
08-23-2007 01:14 PM
walzman
08-15-2007 08:27 PM
magnum27
5
07-08-2005 08:16 AM
bripar77
0
01-30-2005 03:06 PM
NetGain
2
06-28-2004 03:44 PM
