New Boat, New Truck?
Old 09-20-2005 | 07:03 PM
MarkDonzi's Avatar
Default New Boat, New Truck?
I want to pull a Donzi 38ZR, approximate dry weight of 9,200# plus a myco tri axle trailer.
Is a Ford F350 Superduty with the 6.0 Diesel up to the task. I don't want to buy a dually unless I absolutely have to.
MarkDonzi is offline
Old 09-20-2005 | 07:12 PM
Sean H's Avatar
A to Z
Default Re: New Boat, New Truck?
yes.....
Sean H is offline
Old 09-20-2005 | 07:51 PM
GLH's Avatar
GLH
Originally Posted by Sean H
yes.....
What Sean so eloquently said.
GLH is offline
Old 09-20-2005 | 07:53 PM
BZ's Avatar
BZ
I had a single wheel truck and then went to a dually, the biggest difference is that you will love the stability that the dually offers. It is HUGE difference. I only tow a 35ft FOUNTAIN on a Myco and would be had pressed to tow/buy anything but a dually!!!!!!!!just mu .02................BZ
P.S. buy the dually
BZ is offline
Old 09-20-2005 | 08:55 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That truck will be fine as long as you have a signifcant wheelbase. If you have a standard cab with either bed, or a short bed and extended cab; you are going to have some sway, and want a longer truck. Any other configuration should be fine, but I HIGHLY recommend rear airbag suspension helpers. Best $300 (installed) you can add to ANY truck.
Sydwayz is offline
Old 09-20-2005 | 08:59 PM
DollaBill's Avatar
OSO OG
truck seems a little big for that job.
DollaBill is offline
Old 09-21-2005 | 10:08 AM
ZBODaytona's Avatar
I have seen older 350 single wheels tow more than that. So the new 350 will be just fine. Like stated above the longer the truck the better. True the dually will be more stable, but with what you want to do you don't really need it.
ZBODaytona is offline
Old 09-21-2005 | 11:04 AM
We pull our 35 fountain with a 05 crew cab dually. Tried it with a F 250 PS with a moderate lift and it was a no go up tight hills. Love the dually, stability is important, plus it may be overkill now, but you can pull something bigger later. Just thought i would throw that out there
FOUNTAINFAMILY is offline
Old 09-22-2005 | 09:32 AM
pachangalpina's Avatar
I don't know about the single rear wheels but I had issues at the ramp with my dually. Late in the season I had issues with pine straw and could not get enough traction. It was pretty embarrassing when my wife had to hook a tow strap to her BMW 5 series wagon to pull me out. I just replaced my '01 F350 2x4 dually with a '05 F350 4x4 dually. I really did not want the 4x4 but found that those few times a year were all that was needed to make me want to switch. I tow a 38 Fountain Fever which is about the same weight as your Donzi. The dually may not be necessary but I really like the stability. I also move equipment and materials around for work and the dually has been great for that.
pachangalpina is offline
Old 09-22-2005 | 09:48 AM
The SRW F-350 is certainly adequate for pulling your boat. If you are interested, I currently have an 01 F-350 Crew Cab, Single Rear Wheeel, Long bed for sale. Lariat trim, Leather, heated seat, 6 disc in dash changer (factory) all the other bells and whistles. Can give you a significant break over new price. Truck has 93,000 miles. Contact me at 443-286-6350 ifinterested and I can email pics and more specifics.
Treads is offline
