Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Add new without repainting all? >
Old 09-21-2005 | 11:42 PM
Default Add new without repainting all?
I am going to install a new forward cockpit, dash and partial front deck after i cut out the old one. I would like to do most of the glass work before I do this to include building the dash (done), deck, throttle quadrant, etc.....glassing it, painting it, mounting most of the gauges, pre-wiring it, and then dropping the assembly into the boat.
My question is: is it possible to blend in the existing white deck color with the new construction? Do I have to go to a paint shop with a piece of the old deck so they can mix paint to match like they do for homes?
Question 2 - Assuming the match in paint can be made - what about the clear coat that goes on next? How do you blend that in to the existing clear so there is no visible discontinuity?
Thanks in advance.....TJ
tj309 is offline
Old 09-23-2005 | 06:25 AM
Audiofn's Avatar
Charter Member #232
Default Re: Add new without repainting all?
Is your boat painted on the dash? Most are Gell.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-23-2005 | 10:35 AM
Its all Gell.
tj309 is offline
Old 09-23-2005 | 11:44 PM
DirtyMoney's Avatar
What kind of boat?
Some gels can be matched with factory color, however age will discolor.
DirtyMoney is offline
Old 09-27-2005 | 02:08 AM
If the deck and hull are separated by rub rail, the deck can be painted separately w/o being noticeably different from the hull assume you matched the color w/cutout sample as you mentioned. You don't want to blend paint to gel unless there is a good breaking point b/t them i.e. 90 degree radius or style line. G$
Gmoney52 is offline
Old 09-27-2005 | 09:22 AM
is it possible to do my additions in gelcoat and then meld it into the existing gel?
tj309 is offline
Old 09-27-2005 | 12:58 PM
magnum27's Avatar
oh yes just will require more wet sanding and polishing
magnum27 is offline
Old 10-02-2005 | 10:05 AM
Catagory5's Avatar
That is the correct way to make this repair..Blend the new glecoat into the old. Getting the color match is the real trick.
Catagory5 is offline
Baddogg
1
11-07-2007 06:16 PM
haulinvols
4
10-02-2006 03:21 PM
MnFastBoat
7
07-08-2002 05:14 PM
delsol
06-07-2002 02:22 PM
Audiofn
10
02-26-2002 09:15 AM
