Mercury/Quicksilver Spanner Wrench... B1 Trim Cylinder End Cap Removal >
Old 09-29-2005 | 03:47 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Mercury/Quicksilver Spanner Wrench... B1 Trim Cylinder End Cap Removal
Tool needed to remove the end cap of a B1 Trim Cylinder:
Merc P/N : 91-821709
I don't have any spanner wrenches; never even used one. Can this be picked up as a Craftsman or Snap-On part?
Thanks!
Sydwayz is offline
Old 09-29-2005 | 05:18 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Mercury/Quicksilver Spanner Wrench... B1 Trim Cylinder End Cap Removal
Brian, nothing special about spanner wrenches. Pick up an adjustable one over a fixed one. Just make sure the pin dia's are not to big for what you need. There are different sizes. I don't know what size you need off hand.
http://www.sears.com/sr/javasr/produ...table+Wrenches
You can make a cheap and dirty one using bolts for the pins.
US1 Fountain is offline
Old 07-04-2007 | 07:16 PM
This is a 6 year old post, and if you can remember, did you use an adustable spanner to get the end cap off?
Peter Jones is offline
Old 07-04-2007 | 07:17 PM
Sorry, it is only a 2 year old post.
Old 07-07-2007 | 08:47 PM
I made one and you can use it if you like. [email protected]
baronbob is offline
Old 07-08-2007 | 08:57 AM
hoozeyurdaddy's Avatar
an adjustable spanner will work fine, just use the right size, put it on the ram and tap it with a mallet.
hoozeyurdaddy is offline
sonic28
2
09-18-2007 07:50 AM
sonic28
0
09-17-2007 02:07 PM
Sydwayz
09-30-2005 11:58 AM
SSComp
2
05-20-2004 05:39 PM
Dusty Times
03-19-2004 08:12 AM
