Jump start adaptor??? >
Old 09-30-2005 | 10:04 AM
corbvette's Avatar
Default Jump start adaptor???
I have a 2000 32 with twin 502's...There is a female plug adapter mounted on the base of the rear seat used to jump start the boat if the bateries are dead. (batteries are under the power engine hatch) I can not find a male adapter anywhere that will plug into this.....I bought the boat used so I don't know if it is suppose to come with boat or not?!?!?!?
Any help??????
corbvette is offline
Old 09-30-2005 | 10:33 AM
pachangalpina's Avatar
Default Re: Jump start adaptor???
Not sure about the newer boats but my '89 has a household type Dryer outlet under the rear seat. Then a jumper cable with a dryer plug is used to connect to it. Sounds odd but works very well. I think that some of the newer ones use hook-ups like you see on some race cars and trailer winches.
pachangalpina is offline
Old 09-30-2005 | 11:57 AM
DragonFire's Avatar
My 04 came with the cables that plug in to that connector.
Call any Fountain Dealer, I am sure they can order you the cable...
Good Luck
DragonFire is offline
Old 09-30-2005 | 12:03 PM
corbvette's Avatar
Thank you!
Old 09-30-2005 | 05:12 PM
epeek's Avatar
Napa sells them,its the same setup for external cables
that tow trucks & emergency equipment uses. If
you cant find it let me know. I have an extra set of
cables from my brothers 29 when it sank.
epeek is offline
Old 11-09-2005 | 02:01 PM
sleeper_dave's Avatar
search function works!
good info, i'm hitting up NAPA.
want to use this sort of as a security feature (amps are under the hatch). I'll pull the batteries for winter storage and power the hatch closed on the jumper cables. probably have to tape up or otherwise cover the battery connections though so it doesn't short out.
sleeper_dave is offline
Old 11-09-2005 | 09:03 PM
GOODT's Avatar
its also the same as the connection for charging fork lifts
GOODT is offline
Old 11-10-2005 | 08:31 AM
Wally's Avatar
Were doomed!
This what your looking for? its for the connector only...you supply the jumper leads...
http://www.partsexpress.com/pe/showd...number=263-120
-Wally
Wally is offline
dean campbell
3
05-25-2005 09:58 AM
tahoeguy318
5
05-14-2005 03:14 PM
tomtbone1993
01-09-2004 08:32 AM
Sydwayz
11-04-2002 08:43 AM
