Full Hyd vs Mechanical0-Hyd steering Pros & Cons >
Old 10-05-2005 | 11:29 AM
Rage's Avatar
Default Full Hyd vs Mechanical0-Hyd steering Pros & Cons
Can some one explain the pros and cons of full hydraulic steering system versus a mechanical steering system with power assist that has been converted to a single ram external steering?
This would be for a Mercruiser 496HO Bravo 1 single drive.
Thanks!
Rage is offline
Old 10-05-2005 | 12:20 PM
Default Re: Full Hyd vs Mechanical0-Hyd steering Pros & Cons
Rage the add on system using the cable helm will still allow some well play, the full hyd setup will be tight. The helm and hoses will not cost that more. Go with the full system
mmwalters is offline
Old 10-05-2005 | 02:19 PM
Rage's Avatar
What full hydraulic steering system mfg's are out there to choose from and which do you like?
Thanks!
Rage is offline
Old 10-05-2005 | 03:12 PM
CPPerformance's Avatar
We carry systems by:
Mayfair By Hardin Marine
Marine Machine
WPM
IMCO
Just to give you a few more choices. Check our web site for pricing and product details at www.cpperformance.com
CPPerformance is offline
Old 10-05-2005 | 09:11 PM
AIR TIME's Avatar
I have the M/M ADD ON I need to go full, add on SUCKS I have a ton of play my cable was new to waste of money I went out on sat for the frist time in two years boat was chinewalking real bad from 65 to 75 Icouldn't trim it out all the way so how much for the helm and pump to make it full any deals art
AIR TIME is offline
Old 10-05-2005 | 09:20 PM
Scarab28's Avatar
One more question - On a single engine - when do you need two cylinders versus a single cylinder?
Scarab28 is offline
Old 10-05-2005 | 09:39 PM
The helm pump is not to bad $ wise if you are willing to use the stock steel streeing post. Then you will need hyd hoses of course Check with trick or IMCO or these suppliers on this site. Make sure you buy the steering post with the 3/4'' shaft.
I would think a single cylinder is good with a single motor
Old 10-05-2005 | 09:43 PM
AIR TIME's Avatar
when you have the money when you have two its better for the gimbal I will do it after I go full helm because I bought a extra ram from someone on her and it was the wrong size I HAVE A 9'' ON THE BOAT THE ONE HE SENT ME WAS A 7'' so anyone looking for a 7''ram M/M MINT
AIR TIME is offline
Old 10-06-2005 | 10:18 AM
Rage's Avatar
Can someone direct me to a schematic layout of a full hydraulic steering system. I am having trouble understanding where all the 'pumps' are located and how many there are etc.
What is the deal with different size steering wheel posts/shafts. What other upgrades changes are required when converting from power assisted mechanical steering to full hydraulic beyond the 'kit'.
You guys are right, there does not seem to be that much difference in price between the full hyd kit and the upgrade to external steering kit. Am I missing anything?
Thanks!
Rage is offline
Old 10-06-2005 | 10:34 AM
Dave M's Avatar
Veteran: Navy
Check out IMCO's site. They have complete system diagrams.
http://www.imcomarine.com/pages/nev-....html#helm%201
Dave M is offline
