dyno'd my 540 today >
dyno'd my 540 today
dyno'd my 540 today
Old 10-07-2005 | 05:42 PM
Default dyno'd my 540 today
I thought it did pretty good except the torque peaks way early.
10:1 c/r
crower 10404 cam(292 int, 303 ex dur, 110 lobe center, about 600 lift)
dual plane manifold
GMPP oval port aluminum heads (110cc)
Demon 850 dp carb
I'd like to see the torque peak closer to 4500, would a single plane intake help much?
cmcnitt is offline
Old 10-07-2005 | 06:06 PM
articfriends's Avatar
Default Re: dyno'd my 540 today
I'm surprised the tq peak is at 3600 rpm's,most big blocks similar to yours are around 4400. What is cam duration at .050? Smitty
articfriends is offline
Old 10-07-2005 | 10:27 PM
Do you know what the correction factor was when you dyno tested?
RumRunner is offline
Old 10-07-2005 | 11:56 PM
RR, see attached.
I just got this boat and it seems real sluggish after about 4500 rpm (half throttle). Anything over half throttle doesn't seem to add much speed, it ran about 70mph at 4800 (just over half throttle) and slowly creeped up to 77 at full throttle. It wouldn't bother me so bad if it was more responsive but it is too d#$! sluggish the way it is.... I just don't know what the best bang for the buck would be at this point.
Thanks!
Chris
cmcnitt is offline
Old 10-08-2005 | 10:52 AM
PatriYacht's Avatar
The heads are the culpret here. You could have some porting done or you could crutch the heads by using a cam with a little more duration. More duration means more overlap ( time when both valves are open) and that could mean reversion. With an engine that size I would definatly use a single plane.
PatriYacht is offline
Old 10-08-2005 | 11:00 AM
Originally Posted by sutphen30
cam is 01404 and specs are 236,245 ls110
i'd try a single but those heads are a little restrictive for a 540.you should get some port work done on them.
I agree,something is a definate restriction here,the cam isn't all that small. Do you have any flow #'s on the heads? Smitty
Old 10-08-2005 | 02:55 PM
Have you pulled a plug yet?
Old 10-08-2005 | 08:52 PM
I haven't had the heads flowed, they are stock gmpp part number 12363392. I couldn't find any numbers on them. The plugs look good, I ran the boat today with an o2 sensor and it runs around 12.5 afr. The boat jumps right out of the water but runs out of steam after about 4300 rpm. It sounds like I need to swap the heads and intake..
Chris
cmcnitt is offline
Old 10-08-2005 | 10:37 PM
GM heads part no. 12363392 are oval ports, designed for 396 through 502's. 2.19 I, 1.88 E stainless steel valves. Probably not enough flow for a 540.
Hope this helps.
Kidnova is offline
Old 10-09-2005 | 12:42 AM
Bulldog's Avatar
I may be wrong, but oval ports sound small for a 540.
Bulldog is offline
Shore Thing
Velocity
51
05-06-2007 01:13 AM
hondatv
5
07-10-2006 08:40 AM
Vinny P
49
12-10-2004 06:54 PM
Hydrocruiser
09-28-2004 09:44 AM
tripps
11-28-2002 03:18 PM
