Dana Marine exhaust?????? >
Old 10-13-2005 | 07:55 PM
Default Dana Marine exhaust??????
Anybody using the dana marine exhaust? Just curious what kind of hp or torque these have over stock manifolds. Have 454 mag efi motors 385 hp. Looking for some new exhaust. Any suggestions? Looking for biggest bang for the buck
obsessioncatsass is offline
Old 10-14-2005 | 10:12 AM
dana marine products's Avatar
Default Re: Dana Marine exhaust??????
You can expect to lose roughly 80 lbs of weight per engine, gain 35 HP and 35 ft lbs of torque.
dana marine products is offline
Old 10-14-2005 | 10:14 AM
LIOPA's Avatar
We ran a FORCE OFFSHORE CAT with a pair of in house FORCE NA 625 HP with the DANA set up. They worked very well. I highly reccomend them. GOPS of torque and superior workmanship on the product.
LIOPA is offline
Old 10-14-2005 | 11:33 AM
zimm17's Avatar
Dana Marine- How would these work on a closed loop cooling system in salt water? I could run antifreeze through the lower and cool salt water exiting through the risers, or would you recommend salt through the whole thing? I don't know if 190 degree water will cool the lower manifold enough.
zimm17 is offline
Old 10-14-2005 | 07:44 PM
The manifolds are easy to plumb on a closed system. 190 degrees is high, 160 would be better. The manifolds have a closed riser flange so there's no potential for a leaky gasket at the riser flange.
288sunny
9
06-21-2007 07:56 PM
Rage
41
02-18-2007 09:42 PM
New Products and Member Discounts
20
07-30-2006 11:15 PM
TomR
7
11-01-2005 07:28 AM
SledgeHammer
23
03-12-2003 11:14 AM
