Best All Around Prop on 34' Scarab III 330/TRS >
Old 10-13-2005 | 09:10 PM
Cig35Mistress's Avatar
Default Best All Around Prop on 34' Scarab III 330/TRS
What's going to be the best matched propeller for a 1984 34' Scarab III with stock 454/330's and TRS drives? I'm looking for decent holeshot, excellent/economical midrange, and decent top end. Is that too much to ask? Oh yea, it's gotta be cheap too! Thanks guys, look forward to hearing something soon.
Harry
Palm City, Florida
Too Many Boats . . .
Cig35Mistress is offline
Old 10-13-2005 | 09:19 PM
BajaRunner's Avatar
Default Re: Best All Around Prop on 34' Scarab III 330/TRS
Ive got a pair of 21p mirage plus rh/lh ill make you a deal on if it will work for your setup.
BajaRunner is offline
Old 10-14-2005 | 12:47 AM
phughes69's Avatar
Harry are you looking for props for your boat or someone else's? Do you still have the speedy II's on your boat?
phughes69 is offline
Old 10-14-2005 | 01:37 AM
I'd be interested in the 21P Mirage props if they would work on the Scarab with the setup that I am talking about. I still have the Speedmaster II's on my 35' Cigarette Mistress. I recently purchased this 34' Scarab as a quick project to play with.
Old 10-14-2005 | 07:57 AM
throttleup's Avatar
Most likely for your set-up Mirage Plus propellers. Your drives, if original may be to deep for 4B props. Post some performance numbers on your current set-up and props. We can go from there.
Julie
throttleup is offline
Old 10-14-2005 | 08:16 AM
BajaRunner's Avatar
Cig35, your pm box is full.
Old 10-14-2005 | 11:40 AM
gotime34's Avatar
Cig 35, I have an 85 Scarab III. When I had 400 HP I used Mirage 23P, and they were a great all around prop. I still have them if you are interested.
gotime34 is offline
Old 10-14-2005 | 12:03 PM
Lofty's Avatar
I have a set of Mach 26 4 blades that ran great on my TRS Fountain 8.8m with the same power. I'll make you a deal on them.
Lofty is offline
Old 10-14-2005 | 12:37 PM
throttleup's Avatar
Lofty what diameter are the props? 4B props always improve performance, so if you can run them its great.
Julie
Old 10-14-2005 | 04:04 PM
Scarab3DMC's Avatar
HYDROMOTIVE Q-IV'S...22'' 15 1/4 DIAMETER...been there done that....HI JULIE..!!!!
Scarab3DMC is offline
fendari
Scarab
16
02-27-2009 09:49 AM
86badmedicine
Scarab
3
10-17-2006 03:19 PM
Cig35Mistress
Scarab
0
10-13-2005 09:11 PM
guilderoy
Scarab
3
07-05-2004 09:09 PM
tomcat
21
03-17-2004 01:12 PM
