oil flow direction ? >
Old 10-18-2005 | 03:11 PM
Default oil flow direction ?
so should the oil got from block to cooler to filter to block OR block filter cooler block ?
boatman747 is offline
Old 10-18-2005 | 03:21 PM
Wobble's Avatar
SORE MEMBER
Default Re: oil flow direction ?
1/ Some say block-filter-cooler-block.
2/ I prefer block-cooler-filter-block. This is because building a cooler involves a lot of soldering and I am always afarid there will be some solder balls that will get loose after time and get into motor.
I beleive OEM is method #1
Wobble is offline
Old 10-18-2005 | 03:36 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
This is how we would do it
File Type: pdf
teaguecustommarine is offline
Old 10-18-2005 | 03:41 PM
I cant open the darn file can you explain it please
Old 10-18-2005 | 03:48 PM
I have exactly the same philosophy as Wobble. Especially true with used/reused coolers and lines.
Gary Anderson is offline
Old 10-18-2005 | 03:59 PM
lets try this
out of the block
into the cooler
into the filter assy
back to the block
Old 10-18-2005 | 09:11 PM
formula31's Avatar
Hmmm, warmer oil flows easier through filters, Ill stick with the tried and true Merc method of block, filter, cooler.
formula31 is offline
Full Force
0
05-28-2008 08:41 PM
JnT
2
05-04-2008 05:44 PM
Active Mike
10
08-24-2004 09:48 PM
502procharger
3
07-12-2004 01:51 PM
Johno
12
06-26-2003 12:56 PM
