New cabin carpet, bind or not bind edges??? >
Old 10-25-2005 | 08:08 AM
East Coast B's Avatar
Question New cabin carpet, bind or not bind edges???
The current carpet in my cabin has binded edges on parts, but not others.....
What are others doing when replacing the cabin carpet? Are you binding the edges or just butting in the cut carpet edges??
What are they doing in the new boats from factory?
If I were to go with binding, where do you go to get this done?
Thanks!
East Coast B is offline
Old 10-25-2005 | 08:29 AM
hillbilly24's Avatar
Default Re: New cabin carpet, bind or not bind edges???
I would bind it and make it removable. That way if you evr get water in there you can tke it out to dry it instead of ending up with a nasty smelling moldy cabin. Most carpet places can bind it for you, when I had the carpet done at my house a few months back I had them turn some scraps into some door mats for me they did it right at their store.
hillbilly24 is offline
Old 10-25-2005 | 08:43 AM
Absolutely bind it. Install snaps in floor and have eisenglass tabs sewn in at snaps on carpet and use thin rubber mesh cabinet liner on the floor under the carpet to keep it from sliding around and eventually stretching.Take the carpet out regularly to air out and vacuum. It will stay looking great for years.
deboatmon is offline
Old 10-25-2005 | 01:13 PM
I'm for the wall to wall or that would be stringer to stringer look.
Back4More is offline
Old 10-25-2005 | 01:35 PM
OK.... plan to bind it and make it removable with underlayment liner to keep it from moving and snaps or something..
Now.... When I go to cut the carpet and fit it, should I cut it so it's tight as possilbe or leave some room on the edges for the binding? I'm wondering if the binding will increase or decrease the size of my cut carpet? I want to get a tight a fitting as possible...
Thanks for all your good insights!!!
Old 10-25-2005 | 07:49 PM
Make a template and take it to the carpet people that way they can mak it the exact size you need.
26sonic
Sonic
1
06-18-2007 01:29 PM
klmken
09-28-2006 12:53 PM
Boomer35
01-05-2006 10:27 AM
alpine99
Fountain
6
02-03-2005 10:51 AM
stevewix
3
04-20-2004 12:18 PM
