DC/VA/MD area... Does anyone have a motorized trailer mover? >
Old 10-26-2005 | 11:29 AM
Sydwayz's Avatar
Forum Regulator
Default DC/VA/MD area... Does anyone have a motorized trailer mover?
I need to use/borrow/rent a powered trailer mover that is very compact; similar to:
http://www.powercaster.com/
http://www.compcor.com/trailertug.html
http://www.powermoverinc.net/
I am trying to put my boat inside a friend's barn for the winter, but I have to use something like this to manuever it in beside his boat.
I can rent something like this for a day for about $150 bucks, but its still probably going to be too big.
Little help? Thanks in advance.
Sydwayz is offline
Old 10-27-2005 | 10:14 AM
Dave M's Avatar
Veteran: Navy
Default Re: DC/VA/MD area... Does anyone have a motorized trailer mover?
This might be a stretch but what about those things people put under the wheels of cars to move them around? Put one under the tongue. If you are on a level surface a few people could push. Or, use a come-along.
Dave M is offline
Old 10-27-2005 | 10:44 AM
Sydwayz's Avatar
Forum Regulator
Thought about that too, as the boat has to be pulled into its parking space. Its a 37' AT weighing around 11,500 lbs. as it sits now. Floor is concrete, but its a matter of threading a needle, and butting the coupler within a few feet of a corner.
Sydwayz is offline
Old 10-27-2005 | 10:58 AM
Do they have a tractor? My Dad has a trailer ball attachment for his bucket on the front of a Kabota tractor. Works like a charm for moving trailers around.
Shah Mat is offline
Old 10-27-2005 | 11:03 AM
jollyroger's Avatar
You might want to try this. A friend of mine mounted a Class IV hitch to the front of his truck (Chevy 2500). He uses it to move his Fountain 10 Meter into some tight winter parking. It makes moving boats around in tight spots pretty easy.
Woodsy
jollyroger is offline
Old 10-27-2005 | 11:39 AM
BAJA342's Avatar
Charter Member #1251
Brian,
Don't forget that what ever you use, you'll need it to get back out also. Besure to have avail. come spring.
Frank
BAJA342 is offline
Old 10-27-2005 | 11:43 AM
I have a 4x4 Kubota tractor with a front loader with bucket teeth. I use mine to move mine around. I am in Haymarket, where are you located?
88Fountain is offline
Old 10-27-2005 | 11:45 AM
Sydwayz's Avatar
Forum Regulator
Thanks everyone. Unfortunately, a front hitch won't work, but I would not mind having one someday. Once I snag a dually, I am sure I will install one.
I really need a powered device that is tiny for this task.
Sydwayz is offline
Old 10-27-2005 | 11:49 AM
Sydwayz's Avatar
Forum Regulator
88Fountain, I am pretty sure we have crossed paths before. You were restoring your boat in a barn right? I bought some property off the side of Bull Run Mountain a couple years ago, and since sold it. I am trying to put the boat in storage in Culpeper at a good friend's place. I am currently in Woodbridge, but moving further south hopefully sooner than later.
Sydwayz is offline
Old 10-27-2005 | 11:58 AM
Check some local riggers machinery movers.. they use skates that will handle plenty of weight....
you can put them under your tires at whatever angle you need and keep changing the angle until you thread the needle.
Just a thought..............good luck.
Danny Usnik is offline
