Stellings Jacketted Pipes - What is supposed to seal the joints >
Old 10-30-2005 | 09:50 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default Stellings Jacketted Pipes - What is supposed to seal the joints
Started taking all three engines apart. The engines have Stellings jacketted pipes. The middle engine has the headers, long extensions, and finally the downturned extension. The other two engines have just the headers and the down turned extensions.
After I'm done with the engines, and go to install the headers, what is supposed to go in the joint area to seal the joint?
Fred
waybomb is offline
Old 10-30-2005 | 10:04 PM
2112's Avatar
Default Re: Stellings Jacketted Pipes - What is supposed to seal the joints
RTV silicone although the mechanical fit is pretty good without any sealer.
2112 is offline
Old 10-30-2005 | 10:06 PM
waybomb's Avatar
2112 - Yup, that's what was in there. Just didn't sem right, but I gues it is!
Thanks.
Fred
waybomb is offline
Old 10-31-2005 | 06:18 PM
GOODT's Avatar
I use high temp rtv black, also put alittle mercury 101 on the bolt theads
GOODT is offline
NJgr8ful
Swap Shop
7
11-12-2008 09:19 AM
BillR
3
03-30-2007 05:21 PM
OldSchool
05-16-2006 11:43 PM
baja36ft
8
02-06-2005 03:14 PM
nebulous
05-06-2002 02:01 PM
