More Power
I Have 525sc's In My 38 And Want More Power,I Have Already Installed Chillers And Pulleys And Do Have More Power Than Stock But Now I Want More!cams,Heads Etc Or Do I Scrap These Engines And Start From Scratch!Whats The Best Way?How Much More Will The Right Cams And Heads Change The Engines Or Are These Things Maxed Out Now? Thanks!
You can probably get some ideas from guys on here, but I would suggest that you would still/eventually PM "rmbuilder"...he has the knowledge, experience, and integrity to help you get set up with the right head/cam combination for the cubic inch size of your engines, type of application, etc. He has helped me with my combination, and several others here.
It is my understanding that increasing the cubes with the same blower will drop the current max boost some since we are now feeding a larger volume. I would want to know if you would still gain horsepower with the lower boost if you keep the present blower.
I'd say scrap the old induction and drop on some 8-71s at around 7-7.5psi with some roller cams....
Come to think of it, MSD ignition and spinning it at 5600rpm should help too.
Forget the rod deal, a .250 longer rod may give you 5-7hp.
Originally Posted by JJONES
im not sure if the 250 will fit the coolers,i will find out today,thanks!heres a pic of what i have now
What did you find out about a larger blower fitting on your present intake?
