What is fogging your engine? >
Old 11-01-2005 | 08:16 AM
BajaRunner's Avatar
Default What is fogging your engine?
What exactly is fogging your engine? I know probably a dumb question, just never done it before.
BajaRunner is offline
Old 11-01-2005 | 08:26 AM
jb
Default Re: What is fogging your engine?
I just did it yeaterday.. wish I could tell you what the heck it does, I dont remember what teh language my mechanic was speaking..lol... but I was putting awhole bunch of fogging oil in the carb.... sprays in like a carb cleaner can
jb is offline
Old 11-01-2005 | 08:27 AM
DoTheMath's Avatar
Basically, it is running your engine and squirting (while running) Marvel Mystery Oil, (or similar) through the intake until it smokes out the exhaust. This coats the internals of your engine - keeping moisture from doing any harm during storage or long periods of not running.
DoTheMath is offline
Old 11-01-2005 | 08:32 AM
Chris288's Avatar
Easy to do w/ carb motor, a bit more hassle w/ EFI.... while pouring anti-freeze through the muffs pour Mystery oil or 2-stroke or fogging oil down the carb until it chokes out and stalls. W/ EFI I pour most of the antif-feeze through the muffs then pull off the fuel filter dump out most of the gas and fill up w/ 2-stroke oil and start it up while finishing off the last half gallon or so of anti-freeze
Chris288 is offline
Old 11-01-2005 | 09:09 AM
The Menace's Avatar
Inhibits rust and or corrosion formation on the cylinder walls, heads, intakes, pistons, etc, etc.
Also fouls you plugs.
For those of you who store outside or in non heated buildings, you would be amazed at the amount of condensate that is deposited.
The Menace is offline
Old 11-01-2005 | 09:18 AM
mr_velocity's Avatar
Be very careful about pouring so much that is stalls, I have seen motors hydraulic lock when tried to start in the spring.
mr_velocity is offline
Old 11-01-2005 | 12:38 PM
Chris288's Avatar
True, I never put in so much that it konked out,, just coughed sputtered and shut down..
Chris288 is offline
davis777
19
10-05-2011 10:15 PM
Magic1
5
10-28-2008 11:49 AM
Craney
23
09-18-2008 06:03 PM
Magicfloat
06-07-2007 07:48 AM
wrinkleface
10
10-01-2006 07:56 AM
