Older stainless Marine exhaust >
Old 11-10-2005 | 03:51 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Older stainless Marine exhaust
I bought 2 sets of the older SM exhaust with alum. risors, to replace my stock cast iron exhaust. Would have prefered Gils, but the price was right. These manifolds are basically the same design as the stock manifilds: open manifolds, no dividers.
I'm expecting zero performance gains, which is fine. Reasoning for the change is to eliminate 160# , and eliminate the chance of the leaky risor to manifold gasket.
Is there any reason not to use these? Motors will never be modified. 502MPI's
US1 Fountain is offline
Old 11-11-2005 | 07:39 AM
RLW
Default Re: Older stainless Marine exhaust
Call Brownie@SM if he doesn't chime in for your answer.
RLW is offline
Old 11-11-2005 | 03:53 PM
Ginger or Mary Ann?
So, there are no problems/issues with these manifolds, or nobody knows squat about them?
Old 11-14-2005 | 08:45 AM
Those aluminum risers CANNOT be used on a high performance engine. They are cylindrical (no nozzle) and will hoover water at idle. Great and long lasting for STOCK engines with non-lumpy cams.
BROWNIE is offline
Old 11-14-2005 | 05:30 PM
Ginger or Mary Ann?
Brownie, thanks. I assume they are fine for my stock 502 MPI's then.
Old 11-15-2005 | 07:13 AM
Chit! I didn't realize that these two messages were from the same guy. No! Don't use these risers on that engine. I recommend long risers for the 502 MPI. Call me at 305-681-7892 for more info.
BROWNIE is offline
Old 11-15-2005 | 04:36 PM
Ginger or Mary Ann?
Brownie, tried to call, but no answer.
Guess I'm not following here. They would seem like a direct replacement for what I have, stock cast iron merc exhaust with silent choice. I understand that longer risors are preferred, but everyone has short risors for use of silent choice on BBC's. I must not be seeing the whole picture.
Will try to get ahold of you Wed morning to talk in detail.
Thanks,
Jerry
Old 11-16-2005 | 07:04 AM
The difference is backpressure. Ours (or anybody elses besides Merc) are free flowing. Freeflowing = larger area. Same amount of gas, larger area = lower gas velocity. Low gas velocity can't push the cooling water as far. Your engine is a high performance engine. If you want a performance manifold on it, you will be forced to use either a longer or a nozzled riser. My cellphone: 305-332-7611.
BROWNIE is offline
Old 11-16-2005 | 05:56 PM
Ginger or Mary Ann?
A reminder to search your stash for 2 sets of take offs in case I prefer to go that route. Thanks Brownie for the phone call.
BERTRAM BOY
Swap Shop
6
01-08-2009 08:18 PM
fast22
7
10-07-2008 07:05 PM
US1 Fountain
6
11-22-2005 07:17 PM
US1 Fountain
3
02-21-2005 09:49 PM
StrikinLightnin
2
01-06-2004 08:31 AM
