help me build 540 950 hp >
Old 11-14-2005 | 10:01 AM
CAFE's Avatar
Default help me build 540 950 hp
im ready to start building these two 540 10-71 blower motors. i want 900 hp with 5-6 boost. i also want to be able to run race gas and turn the boost up to 10 lbs or so on occasion. anyone who has a proven combanation please lets here it carbs all the way down to the crankshaft.
thanks
CAFE is offline
Old 11-14-2005 | 12:21 PM
Panther's Avatar
Frank's Marine Service
Default Re: help me build 540 950 hp
Better have some reallllyyyy good heads.
I think 800 hp at that boost level with a 540 is probably more realistic but I could be totally wrong.
Panther is offline
Old 11-14-2005 | 12:37 PM
articfriends's Avatar
I think 950 reliable hp from a 540 with only 5-6 psi of boost will be difficult to make unless you get some really exotic heads and solid lifter cam. I'm right there at 944hp/960 ft lbs tq with my 540 BUT I'm running 9-10 psi of innercooled boost using a centrifugal blower,hydraulic roller cam around .600 lift 234/240 at .050 duration,afr 315 cnc heads,thermal barrier coatings on pistons and heads. It idles at 750 rpm's/10 inches of vacuum,will run on 92 octane,Smitty
articfriends is offline
Old 11-14-2005 | 01:29 PM
CAFE's Avatar
Great numbers. I may contact you if you dont mind.
Doug
CAFE is offline
Old 11-15-2005 | 09:44 AM
ratman's Avatar
run profiler heads and you may need solid roller cams to make that much hp but you can do it. mer made 1240 hp at 6.5 lbs of boost on freds motors they weren't much bigger than 540's
ratman is offline
Dan74
Do It Yourself, Boating on a Budget
23
11-27-2010 05:33 PM
pkspx
Powerquest
24
12-02-2008 08:26 AM
zimm17
51
07-07-2006 10:17 AM
vegas daytona
8
10-26-2005 06:46 PM
Vinny P
11
08-03-2004 09:25 PM
