boat getting "loose" at speed... >
Old 11-18-2005 | 04:38 PM
Default boat getting "loose" at speed...
I moved recently and now that I'm boating on a smooth lake with room to run fast and straight instead of a rough ocean, I've run into a new boat handling phenomenon.
The boat is a heavy old 1970's Cigarette 36, weighing 11,000+ and it has a 9-1/2' beam, Hydromotive Q-IV's turning inward on TRS drives, and a pair of 600 hp BBC's. It's got a single sidewinder stabilizer at the moment but otherwise standard power steering.
Around 65mph on gps the boat starts to feel likes it is very light and it could walk side-to-side at any instant. It will pull past this speed by a few mph but I always end up backing off to get it feeling solid again. Trim is usually ~2 out from straight on the indicators (4 out from fully tucked under).
Is it possible to drive through this and learn the handling?
Or does every given hull and setup/weight have a speed where it gets loose - with this being such an old, heavy and wide boat maybe I've reach what is my top safe speed?
Other comments?
Sandahl is offline
Old 11-18-2005 | 09:30 PM
Default Re: boat getting "loose" at speed...
I just can't imagine that much boat getting that "loose" at 65 mph. Seems to me that you MUST have steering or hull issues. --- Jer
jpclear is offline
Old 11-18-2005 | 10:06 PM
Dave M's Avatar
Veteran: Navy
I agree. Is your steering as old as the boat? Get a better quality steering system. I don't think those sidewinder stabilizers are adequate for big heavy boat.
Dave M is offline
Old 11-19-2005 | 12:23 PM
Steering - good place to start. I didn't really know if it wasn't just normal. First I'll get the other sidewinder back on and see if that helps, otherwise look at external steering. Thanks for your replies!
Sandahl is offline
cobrapower
02-20-2007 07:36 AM
electrical1
11
11-09-2006 08:51 AM
addiction
Nor-Tech
32
09-22-2005 07:52 PM
addiction
08-22-2005 06:33 PM
mikesufka
12-26-2002 11:23 AM
