Metal on drive plug magnets >
Old 11-21-2005 | 11:52 AM
Default Metal on drive plug magnets
I drained my drive oil (Bravo 1) and had metal fines on the drain plug magent and the vent plug magnet. Just enough to cover the magnet tips.
Is this normal? I can't remember if I've ever had metal dust on the top vent plug magent? I use merc drive oil. The oil was dark, less green then when it's new. No metal in the oil just on the plug magnets. 40 hours since last change. Again, the metal on the magnets resembles dust, not chunks, not shavings, but fine dust, and it totally covers the magents of both plugs.
Just can't remember if I've ever had it on the top plug or not. Do I have problems?
-Craig
Ck1flyer is offline
Old 11-21-2005 | 05:24 PM
hpy540's Avatar
Default Re: Metal on drive plug magnets
That seems normal. I have had much wrose. In fact i have never changed oil in one that didnt have some dust or slight sluge on it.
hpy540 is offline
Old 11-21-2005 | 05:34 PM
Mr Gadgets's Avatar
Charter Member #601
Yes.. that is normal to find "dust on the magnets" Rub it between your finger and thumb and if you feel any chunks, at all.. then problems are on the horizon.. From what you describe, you should be ok..
Hope this helps!
Dick
Mr Gadgets is offline
Old 11-22-2005 | 05:57 AM
GOODT's Avatar
Its normal but you might want to consider changing your drive fluid a little more often.
GOODT is offline
Old 11-23-2005 | 07:48 AM
Yeah. Of those 40 hours, most were at 4000-4500 rpms and I bet at least 5 or 6 were at WOT. I figure your going to have a little metal grinding off when you run hard, right?
Ck1flyer is offline
Old 11-23-2005 | 01:07 PM
Yeah. The majority of those 40 hours were at 4000-4500 rpms, and I bet around 5 or 6 at WOT.
Ck1flyer is offline
jdub
Drives and Lower Units
6
06-20-2007 01:09 PM
vandeano
20
11-02-2006 07:18 PM
fulloblarney
4
10-14-2004 09:12 AM
stevejohns
3
07-22-2003 12:47 PM
IHTFP
1
07-07-2002 09:35 PM
