props tarnished/key west water? >
Old 11-23-2005 | 07:40 AM
plumbers crack's Avatar
Question props tarnished/key west water?
Spent 5 days in key west,boat stayed in the water like everyone else's.The props and anything stainless have a gray tarnish on them.I m thinking salt deposits?Anyone know how to clean it off/
plumbers crack is offline
Old 11-23-2005 | 07:46 AM
Default Re: props tarnished/key west water?
"Hammerhead" makes an excellent product for use on stainless or aluminum. Even works well on stubborn stains on your fiberglass hull. (but you will have to re-wax) --- Jer
jpclear is offline
Old 11-23-2005 | 07:49 AM
throttleup's Avatar
This is very common for Key West. There are a couple different ways to remove the white coating.
The quickest way is to use muriatic acid, just pour it on and rinse if off. You can also use some of those house cleaners like CLR but they work slowly.
Matt
throttleup is offline
Old 11-23-2005 | 10:04 AM
Talking Re: props tarnished/key west water?
THANK YOU,bought a product named salt away $12.00 a bottle maybe I will spray on and see what happens?How about on off bottom cleaner/It is an acid but not muric.
Old 11-23-2005 | 10:58 AM
Toilet bowl cleaner. The yucky smelling blue stuff.
Wear gloves.
No elbow grease required.
Pesky Varmint
Pesky Varmint is offline
Old 11-23-2005 | 02:46 PM
lime away, get the same thing at havasu white coating on everything,lime away too it right off
JJONES is offline
Old 11-24-2005 | 03:40 AM
cig1988's Avatar
ON/Off is muriatic acid. If your going to use that...go to a harware store & buy a gallon of it. ALOT cheaper. Carefully put it in a spray bottle & try not to breathe in the fumes. Eventually the spray mechanism will deterioate.
cig1988 is offline
Old 11-24-2005 | 09:32 AM
berns29scarab's Avatar
i use toilet bowel cleaner...squirt on let sit for few minutes, hose/wipe off, spray with WD and done...i use SNO BOWL
berns29scarab is offline
Bobthebuilder
06-11-2015 01:12 PM
Shorgasm
06-14-2006 05:26 PM
gdfatha
10-30-2005 03:57 PM
boatinbill
02-23-2002 05:20 PM
