Anything to winterize on trailer >
Old 11-23-2005 | 01:08 PM
Summer Heat's Avatar
Default Anything to winterize on trailer
Ok, we have our boats shut down for the season, but was wondering is there anything I need to do for a fresh water steel dual axle myco with surge to help her survive the layup?
Summer Heat is offline
Old 11-23-2005 | 02:28 PM
Wally's Avatar
Were doomed!
Default Re: Anything to winterize on trailer
If possible raise the tires up off the ground so you dont get flat spots....other then that...not realy. Put a coating of wd-40 on any exposed metal that may be prone to rust and thats it....maybe put a coating of STP or some other tire dressing that blocks UV rays and she's all good
-Wally
Wally is offline
Old 11-24-2005 | 09:43 AM
mopower's Avatar
Toxic FORMULA
I usually repack wheel bearings after the last use of the season to get rid of any moisture that might br present. I also use tire covers from a camper supply to protect the tires from UV(it helps).
mopower is offline
Old 11-24-2005 | 10:01 AM
carney's Avatar
I always jack up the axles to take any pressure off of the bearings. And put the tires back on the floor.
carney is offline
waterboy222
Grand Lake/LOTO/E-Dock
16
11-01-2007 02:15 PM
pasunbum
Cigarette
1
10-05-2004 09:34 AM
bn
5
09-29-2003 09:01 AM
Intolerant1
01-15-2003 10:29 PM
Luv-N-It
20
11-05-2002 06:18 PM
