Merc. Maximus vent holes >
Old 11-23-2005 | 01:27 PM
Default Merc. Maximus vent holes
I am trying a mercury maximus on my Daytona and have a question on the vent holes. Are these just for through hub exhaust. Do you leave them plugged for through transom exhaust. Is there any benefit to opening them. I might need a little prop slip to get the motor in its torque range so some slip before planing would be OK.
vegas daytona is offline
Old 11-23-2005 | 01:34 PM
throttleup's Avatar
Default Re: Merc. Maximus vent holes
Vent holes are usually reserved for outboard motor applications. It won't hurt to take out the vent plugs, they really don't do much after the boat is on plane. If you don't need them I would leave them plugged as there are some occasions when they may be a problem, especially at minimum planning speeds.
Matt
throttleup is offline
Old 11-23-2005 | 03:00 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Merc. Maximus vent holes
There was a thread at one time on here about the vent holes. I wish I could have you read that.
The vent holes do nothing once the boat bows over and is on plane. The water across the tube closes them. Once you have run the prop and have some good data, we can discuss the options to the Maximus. This propeller has as many or more options to adjustments than any propeller on the market. In other words, inducing slip can be done in other ways.
[email protected]
bbladesprops is offline
onesickpantera
Prop Talk
5
09-08-2008 12:54 AM
Toffen
Prop Talk
6
04-11-2006 10:56 AM
CrazyCat57
1
07-19-2005 04:21 AM
aTX427
Fountain
8
05-10-2005 12:02 AM
Chris288
10-06-2004 10:33 PM
