Air Bags for Rear Suspension?
Old 11-27-2005 | 09:32 AM
Downtown42's Avatar
Default Air Bags for Rear Suspension?
RAM 1997 2500 with factory tow pkg...
What do yo guys use? Need some addt'l support when towing.
Something inexpensive, don't need on-board compressor. I'll just fill them up in the garage before I tow. Thanks.
OR adjustable Air Shocks?
Downtown42 is offline
Old 11-27-2005 | 09:54 AM
Sean H's Avatar
A to Z
Default Re: Air Bags for Rear Suspension?
air bags are the way to go, leave the air shocks for the camaro guys....
the on board compressor isn't that much more and is pretty handy for adjusting the ride after your load/weight has changed...
Sean H is offline
Old 11-27-2005 | 09:57 AM
JCPERF's Avatar
Originally Posted by Sean H
Big bags are the way to go
JCPERF is offline
Old 11-27-2005 | 10:03 AM
Downtown42's Avatar
trouble maker I'm reporting to get my free T
Old 11-27-2005 | 10:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There are so many threads on here I can't even count them.
Search on Air Bags; Air Lift, Firestone Ride-Right
The Firestone Ride-Right system (not sure of spelling) and the Air-Lift 1000 System are fairly equal in quality. Definately get them installed with the ability to adjust pressure in each side. (So you don't have to worry about load shift from bag to bag when filled with one fitting.) I am on my second set of Air-Lift 1000s, and won't own another truck with out them. The on board compressor is not neccesary, but it is a nice accessory, and you can rig it all together with air horns if done properly.
Sydwayz is offline
Old 11-27-2005 | 10:19 AM
offshoredrillin's Avatar
Dave call me at the shop on monday, I put them on my dually i think total cost was 200 bucks. Quality bags work great, easy to put on...
offshoredrillin is offline
Old 11-27-2005 | 10:20 AM
32 caliber's Avatar
When I had my ram 1500 I got air bags from NAPA. I think they were about 350 but worked great.
32 caliber is offline
Old 11-27-2005 | 12:17 PM
jordy's Avatar
I got the Firestone bags with the onboard compressor from Summit Racing and it was something like $400. Don't think I could ever do without 'em. The onboard compressor is sweet as the ride can be adjusted on the fly without having to pull over and find a gas station with air and try to get in and out of there. Just my $0.02.
jordy is offline
Old 11-27-2005 | 12:36 PM
Downtown42's Avatar
Originally Posted by jordy
..... without having to pull over and find a gas station with air and try to get in and out of there. Just my $0.02.
we know how that is then people yelling at you cause you blocked 1 aisle....and they have to drive another 100'
Old 11-27-2005 | 02:46 PM
PMTCHIPS's Avatar
Click this link:
http://www.pmtchips.com/_e/Air_Sprin...4_2002Rear.htm
We have them in stock.
www.pmtdiesel.com
PMTCHIPS is offline
