525 EFI's / SPORTMASTERS / ITS HELP, PLEASE! >
Old 12-05-2005 | 10:03 AM
Joe's Avatar
Joe
Offshore Cowboy
Default 525 EFI's / SPORTMASTERS / ITS HELP, PLEASE!
Ok, Here's the issue. This is the first boat I've had w/ Sportmasters (& ITS / 525 EFI's).
When I launch the boat at the ramp, the motors won't catch prime (no water flow thru sea strainers) - resulting in two shredded impellars, which have been replaced (whole kit, not just impellars) and back-flushed. Since then, still is doing the same thing. I have to give the engines throttle in order to catch prime (which causes fouling of the plugs - not supposed to give throttle when engines are cold etc... as per the Merc. manuel - I've now found is unfortunatly true).
In advance.... Yes, we are backing the boat more than deep enough, making sure the drives are submerged.
Anyone experienced this and, if so, what did you do to solve the issue?
Joe
Joe is offline
Old 12-05-2005 | 10:06 AM
pm203's Avatar
Default Re: 525 EFI's / SPORTMASTERS / ITS HELP, PLEASE!
This may be a supid question, but have you checked the freshwater flush valves?
pm203 is offline
Old 12-05-2005 | 10:15 AM
are they mounted to high? just a thought.
customryder is offline
sea strainer location and plumbing
hope they are not filling from the bottom up??
audacity is offline
Old 12-05-2005 | 10:16 AM
Joe's Avatar
Joe
Offshore Cowboy
Arr..Arr.. Arr... Yep! As I mentioned, it will catch prime when given throttle. It's funny this was the first reply. I almost typed that in! Thanks for the quick thought and response.
One of my buddies did that on his 47 and then proceeded to sweat his @ss off for the next two hours (in 90+ degree temp) replacing all three impellars on the ramp! ...remember that, Scott!!!!
Joe is offline
Old 12-05-2005 | 10:18 AM
Joe's Avatar
Joe
Offshore Cowboy
Might be... Good thought. The ramp is fairly steep. It's a LipShip, so I'd have to wonder (but it sure makes sense).
Joe is offline
Old 12-05-2005 | 10:36 AM
I had same problem with just starboard side and replaced impeller still have same problem boat kept on lift ten feet of water and no problem with port side have to rev to 1000 to get it to pick up same engine set up on 05 38 top gun
topgun 38 is offline
Old 12-05-2005 | 11:16 AM
Joe's Avatar
Joe
Offshore Cowboy
Hmmm.... Strange? Keep me posted and I'll do the same.
Joe is offline
Old 12-05-2005 | 02:24 PM
skaterboy's Avatar
Are you using a "wire reinforced hose" from the sea strainer to the impellar pump ??? If not a dry hose will collapse very easy from the suction of the pump.
skaterboy is offline
Old 12-05-2005 | 02:56 PM
Joe's Avatar
Joe
Offshore Cowboy
Yep... I'm not real technical, but, it's the "stock" set-up from LipShip (the thick/fat black hose - appx. 2" in diameter).
...by the way, Nice avatar/boat! Do you know Bruce Bullock? He's a friend of mine.
Joe is offline
