Block Heater for 2005 Excursion PSD >
Old 12-05-2005 | 05:17 PM
itilldo's Avatar
Default Block Heater for 2005 Excursion PSD
Well, it is supposed to get cold this week here in Ky, 15 degree's at night and I want to hook my Block heater but I can not see it. I bought this vehicle used 2 months ago, so I'm not really sure even if it has one (I do not have the orginal sales list for the vehicle). The manual states it it has this option it should be near the passenger side of the truck near the frt tow hook area. I crawled around on both sides and I still can not see it. Has anyone have any ideas about the location or is it possible that this vehicle did not have one installed from the manuafcutrer.
itilldo is offline
Old 12-05-2005 | 06:05 PM
Outdrive1's Avatar
Masher touches my
Default Re: Block Heater for 2005 Excursion PSD
My plug is under the bumper in the wiring harness on the drivers side by the front town hook. You can't see it unless you look up at the harness. I can find mine real easily now that I know where it is. Not sure how to tell if you have it or not. maybe you can call a dealer with your vin number and have them look up the original equipment list.
Outdrive1 is offline
Old 12-05-2005 | 06:34 PM
itilldo's Avatar
Isn't a block heater kind of mandatory for a diesel?
itilldo is offline
Old 12-05-2005 | 06:59 PM
Outdrive1's Avatar
Masher touches my
Actually in Az. it's not. I don't really know anyone else who has one. Most of my friends think I'm crazy plugging my truck in at night. I like the fact that the heater works almost immediately and you don't have to wait for the truck to warm up.
Old 12-05-2005 | 08:29 PM
With the compression of a diesel....I think like 18 to 1??? It is always nice to give the motor some minor heat when down below 30....you can here the difference when plugged in...we plug all of ours in with timer to come on at 4 am due to electric...not bad this way!
Byrdman is offline
Old 12-06-2005 | 03:05 AM
Scott B's Avatar
If it was not ordered on the vehicle, it is still there. They just add the plug when you check the option box. Worst case scenario, you will need to buy a power cord for it..
Scott B is offline
Old 12-06-2005 | 11:02 AM
Wally's Avatar
Were doomed!
on my BBC Burban...the heater chord was tie wraped inside the engine compartment on the trans cooler lines....i needed to route the plug to the front of the truck to where i wanted it.....check around it may be there just off to the side some place...
-Wally
Wally is offline
Old 12-06-2005 | 11:47 AM
itilldo's Avatar
Originally Posted by Troutly
Never use one up here in MN. I like the smoke and the sound of the pistons trying to swap holes!
You are a nut!!
itilldo is offline
Old 12-06-2005 | 11:06 PM
racinfever's Avatar
I also recently purchased a 2005 F350 Diesel. I ordered this truck with a block heater and I was told like you the cord was in the front by the tow hook. After searching with no success, I took the truck back to the dealer to have them look for it. They reported the block heater was there but the cord wasn't and that they would order it and install it. Apparently the block heater is standard but the cords are installed only where necessary and based on request. Check with your dealer.
racinfever is offline
Old 12-07-2005 | 07:50 PM
Tantrum's Avatar
Just pulled mine down yesterday. It was zip tied to another wire (fog light maybe, wasnt paying attention) in back of the tow hook, in front of the trans cooler.
Tantrum is offline
Michael Garibay
25
05-19-2007 11:41 AM
itilldo
34
11-02-2005 07:51 PM
Eric Froberg
10
10-09-2005 11:36 AM
thunderdan
04-10-2002 11:28 PM
thunderdan
03-03-2002 08:45 PM
