MEFI 3 or 4??? >
MEFI 3 or 4???
MEFI 3 or 4???
Old 12-10-2005 | 06:49 AM
East Coast B's Avatar
Question MEFI 3 or 4???
Looking at a Mercury part # 861721T2 ecu, with a label ECB4 from a 1999 454mag, is this a Mefi 4?
I've done some searching here on OSO and I see that the recommendation is to go with a Mefi 4.
East Coast B is offline
Old 12-10-2005 | 07:15 AM
Default Re: MEFI 3 or 4???
It is a mefi 3. I think I know someone that has one available if you are looking for one.
800XCR is offline
Old 12-10-2005 | 08:57 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Are you looking to upgrade or just replace? The ECB4 is the programing code.
US1 Fountain is offline
Old 12-10-2005 | 09:44 AM
I've got 94 carb 454's right now and looking at complete mpi setup someone took off a 99 454 mag. Again, I think everyone says to go with the mefi 4, so want to be sure I know what I would be buying.
Old 12-10-2005 | 10:04 AM
Dave_N's Avatar
Mercruiser never used MEFI 4. They went from MEFI 3 to ECM/PCM555.
Dave
Dave_N is offline
Old 12-10-2005 | 02:55 PM
Linster's Avatar
Off the Radar
The MEFI 1 has the connections on the small sides of the computer, 180 degrees apart. The MEFI 3 has both plugs facing the same direction on the same wide surface. I am not aware of them using the 2. The 4 as stated above was never used. There is a plug that Merc has came up with to connect to a MEFI4. I hear Merc has no more 3's and are selling 4's as replacements.
Linster is offline
Old 12-10-2005 | 03:45 PM
Looks like it's a mefi 3. Thanks for the descriptions!
Intake Manifold; Intake Plenum ;Injectors ,Throttle Body Assembly, ecu, wiring harness and I'll need an electric fuel pump. What else do I need?
Sending units of any kind?
Old 12-10-2005 | 06:01 PM
Michigan Mad Man
You will need a coolant sensor, Knock sensor, and the intake air temp sensor. We have a bunch of take off parts around if you need them.
TylerCrockett is offline
Old 12-11-2005 | 06:08 AM
Is there any difference in the main plug on the wiring harness for the 99 compared to my 94 setup??? Or will it plug right in??
scarab74
0
03-19-2007 05:13 PM
ls1nova
6
01-16-2007 09:25 PM
poolshrk
Fountain
3
08-27-2004 03:21 PM
poolshrk
0
08-24-2004 10:23 PM
