Mercruiser Part Numbers HELP? >
Old 12-10-2005 | 08:44 PM
Default Mercruiser Part Numbers HELP?
I am an hour from my boat, and have a crazy few weeks ahead, I am hoping someone might know part numbers or some other way to identify and locate some random parts. Thanks In advance. Ok, The boat is a 1983 Excalibur Marine 40' hawk, original twin mercruiser 370 454 7.4L v-8. I just had the long blocks done and reassembled both, I need part numbers or help locating OIL PUMP GASKETS, ALTERNATORS, WATERPUMPS, and possibly MANIFOLDS. thanks
Kevin
spk1 is offline
Old 12-10-2005 | 08:52 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Mercruiser Part Numbers HELP?
The boaters bible, BAM Mercruiser.
http://www.mercruiserparts.com/selec....asp?type_id=8
US1 Fountain is offline
Old 12-12-2005 | 02:04 PM
Originally Posted by US1 Fountain
Thanks for the site, extremely helpful, I am guessing the link for the 330 GM 454 v-8 1982-1987 would be the best pick? mine is a mercruiser 370 454 1983.
spk1 is offline
Old 12-12-2005 | 02:17 PM
GOODT's Avatar
look under 370 trs would be yours 1978-1985 according to my mercruiser epc
GOODT is offline
Old 12-12-2005 | 02:19 PM
Wally's Avatar
Were doomed!
heres the link for the 370: http://www.mercruiserparts.com/selec...doc_nbr=+86187
-Wally
Wally is offline
Old 12-12-2005 | 02:25 PM
The internals/heads on the 330 will be different from your 370. But from your list, the only thing that might be different is the intake manifold gasket.
Thry this:
http://www.dolleroffshore.com/parts....pn=274&bn=1059
Gary Anderson is offline
Old 12-13-2005 | 02:38 AM
Thank you guys. I can finally get the parts I need with out all the guess work and trial and error I had gone through in the past. ( Bringing an oil pump around with me from shop to shop to match the gaskets was getting old) If I can ever return the favor to any of you please do not hesitate.
thanks,
Kevin
spk1 is offline
Old 12-13-2005 | 01:39 PM
Ok, one more issue, I found the Mercruiser part number 817119A4 for the 55amp alternator, I am not sure if the 55amp or 39amp alt. is used on my boat. I currently want to replace the Motorola 8RG2018 alternator that is in it. Will the mercruiser part 817119A4 work?
spk1 is offline
Old 12-13-2005 | 02:20 PM
Wally's Avatar
Were doomed!
Go figure that the 55amp is cheaper then the 39 amp model!!!! anyway why dont you just have yours rebuilt? Last time i had one done it was a tad over $100 with a 1 year warranty....other then if the brushes go bad for some strange reason it will last you alot longer then 1 year It will save you some money work just as good as new and you can still get more stuff
-Wally
Wally is offline
Old 12-13-2005 | 03:50 PM
That is a good idea, and I would at this point do that, except, in my research I found out the non motorola alternator that is currently on my port engine, is automotive, thus not explosion proof, and now I must replace that one.
spk1 is offline
BLOWN85
0
04-10-2008 04:14 PM
team Tickfaw
5
03-09-2008 09:03 PM
Lunatic Fringe
0
05-21-2007 02:20 PM
BY U BOY
1
08-22-2006 06:27 PM
Pantera1
05-02-2006 03:50 PM
